in need of a certain solar cells for my project
nkey292
Mar 26, 2014
11
hello dear friends,
i am new at solar and Photovoltaic energy and would like to find some solar cells adapted to my application ,
i need a current of 0.5Amps with a voltage of 5 volt and as small as possible ( for the current and voltage the serie and parallel associations can solve the problem ) what i need exaclty is the dimensions to be as small as possbile
thanks you guys :)
Gryd3
Jun 25, 2014
4,098
Please remember that the rated output for many panels is in direct sunlight.
Keep this in mind when designing the circuit and de-rate the panels you plan to use to ensure you have a sufficient source to power your circuit.
Depending on your application, buying from EBay or ripping them out of other electronics are the way to go.
What kind of sizes are you limited to? A couple sources online indicate at least 11 Watts / Sq Ft of panel. Using this number alone, you'll need a 6"x6" Square panel (Or equivalent dimensions).
Will you circuit only be on only during peak performance of the panel, or will it be running for extended periods of time?
You may need a larger panel to charge a battery to power the device during cloud-cover or dips in light as the device is running. You may need a larger panel to compensate for the conditioning of the power provided by the panel. You may not be able to make it as small as you want..
nkey292
Mar 26, 2014
11
yes #Gryd3 you are right , but what i have in mind is that i will use an intern battery , that will as long as the panels are exposed to any source of light , store the enery that we will use when we'll need it, so the most important thing now , is the power , because the bigger the power the shorter this battery will charge
thank you a lot , but i need some references , because i have many applications , so i am not in need of just one solar panel , but a lot , so i am gonna need to buy them , not take them from electronics
Gryd3
Jun 25, 2014
4,098
Ok, so from your first post, you have requested a 5V 0.5A Panel.. Chances are you'll have issues find a panel that gives you exactly these numbers.
Look for at least a 2.5Watt Panel. If you are charging a battery for operation during cloud-cover and night, then please average the power requirement for at least a 24 Hour cycle. (2.5 Watts will only provide you with enough juice to provide 150mA at 5V for a 24H period with 8 Hours of ideal sunlight... This would require almost 0 loss in the circuit..)
http://www.digikey.ca/product-detail/en/750-00034/750-00034-ND/2272160
You may very well need to source or build a voltage power supply (most likely Boost type) that will power your circuit and charge the batter.
Anon_LG
Jun 24, 2014
453
Supercap2F
Mar 22, 2014
550
Ebay item number:160968808439 Is a solar cell that measures 13x15cm 5 VDC out 0.5 Amps. Two of them cost about 25 bucks. Looks like what you need.
Dan
Edited $12.59 each
14,486
Just be aware too that panels are usually rated at open circuit output voltage
They drop substantially when loaded. You may find you need a 10V open Circuit voltage panel
READ THE DATA SHEET CAREFULLY
cheers
Supercap2F
Mar 22, 2014
550
Somebody changed what I said. :confused: I really said this:
Ebay item number:160968808439 Is a solar cell that measures 13x15cm 5 VDC out 0.5 Amps. Two of them cost about 13 bucks. Looks like what you need.
Dan
Someone changed it to 25 bucks instead of 13 bucks. Then someone else edited it and said:
Edited $12.59 each
It's really 12.59 for two not one. :D
Dan
nkey292
Mar 26, 2014
11
Dan
lol , i can't do that , if fact i couldn't see the item in ebay , because i have some kind of restriction i don't know why ? can you take me a screenshot of the page please ?
Supercap2F
Mar 22, 2014
550
I attached a screen shot for you. But just type in the item number in to ebays search engine, and it should bring it up.
Edit: make sure your on the USA version of ebay:)
Dan
nkey292
Mar 26, 2014
11
Dan
thank you al lot bro, i will take a look on it
14,486
Dan
NO read the ebay page again Dan !! look at your own screen dump
Quantity 1 for $12.59
I was the one that edited you post ;)
Supercap2F
Mar 22, 2014
550
Maybe I'm missing something, but the "Get lots" drop down list is set to two and It's still 12.59. Am I looking at this wrong?
Regards
Dan
14,486
maybe I am haha
I give up haha
if some one else can confirm you thought, I will re-edit your earlier post and tidy up the thread
14,486
nkey292 hasn't said what country he is from ... maybe ebay is inaccessible there ??
Anon_LG
Jun 24, 2014
453
I still want to know about the overcharge preventative system, do you have one?
Gryd3
Jun 25, 2014
4,098
Well, overcharge may not be an issue if the device draws any more than 330mA (Assuming 8 Hour Night, 16 Hour day with 100% efficiency...) Losses will need to be factored in, as well as non-ideal light conditions.
Of course it is always best to side with caution and put protection in... you skimp on that and you can cause some problems.
