INA125 Incorrect SPICE Model
beedees
Mar 30, 2015
17
Hi everybody!
I'm simulating a circuit with INA125 that is an Instrumentation Amplifier with Precision Voltage Reference. I'm using it with 5V single supply, so V+=5V and V-=0V. I've noticed that if input differential voltages are negative the INA amplifies the signal and if input differential voltages are positive it doesn't amplify. It's a strange behavior! If should be the other way!
I'm using the PSPICE Model provided by Texas Instruments and according to me there is something in the model that is wrong.
I tried to simulate INA125 with a simple circuit too but the result is the same.
According to me a possible error in SPICE Model could be the output (21) of the A1_125 SUB-CIRCUIT and the output (5) of the A2_125 SUB-CIRCUIT.
What do you think about? Have you ever tried to simulate this component? What is your result?
Maybe I was mistaken posting this thread here, if so I'm sorry. But I didn't find a best section.
Thanks all!
14,306
What exactly do you mean by this?
IS this Vin+ - Vin- > 0 and Vin+ - Vin- < 0?
What are the absolute values of Vin+ and Vin-? Are they within the common mode range of the INA?
Also note that the datasheet specifies that it is possible to operate the INA125 from a single supply, but it is designed to be used preferentially with a dual supply since its outputs are not truly rail-to-rail. Try to simulate with a dual supply and compare the result to the single supply simulation.
beedees
Mar 30, 2015
17
Yes, I meant this.
The absolute values are 1.7V and then above the limit reported in the datasheet.
I have already done this simulation but the result was the same. For this reason I think the model is wrong. It's a strange behavior, right?
Surfing the internet I found this. Look at the last post. I think it's the same problem, isn't it?
14,306
Looks like you're right. Have you tried TINA as suggested in the link?
beedees
Mar 30, 2015
17
Yes, I have tried and but it works at the same manner. Unfortunately there isn't the possibility to report this problem to Texas Instruments. I would like to resolve this issue and help others who might waste time like me! :D
