Induction Proximity sensor issue
naeemidrees
Jan 17, 2020
8
I am using induction proximity sensor in my circuit. Some time specially in winter sensor do malfunction. Means sensor randomly trigged. I am use NPN type sensor.
Please help me.
bertus
3,877
Do you have a datasheet of the sensor to post?
That way we can see the properties of the sensor.
Bertus
Minder
Apr 24, 2015
3,561
What would the typical 'winter' temperature experienced by the sensor?
M.
bertus
3,877
Specifications (cont.)
Ambient temperature
Operating : -25° to +70°C (-13° to +158°F)
Storage : -30° to +80°C (-22° to +176°F)
What is the temperature in winter?
Do you have a complete schematic to share?
Bertus
Minder
Apr 24, 2015
3,561
What form does the 'flag' take that triggers the Prox?
What is the nature of the input, any opto etc?
M.
bertus
3,877
I assume you are using a single 24 Volts power supply.
The schematic suggests a dual 24 volts power supply, that would give 48 Volts on the sensor.
The current through the led of the 817 will be about (24 -1.2) V / 5600 Ohms = 4 mA.
Perhaps lowering the resistor value may give a more stable result.
Try a resistor of 2200 Ohms in stead of the 5600 Ohms.
Wich version of the PC817 are you using?
There are 4 different sensitivity ranges.
Bertus
  • PC817 Series.pdf
naeemidrees
Jan 17, 2020
8
I am using PC817 - 1 Channel type.
This circuit drive two 24v solenoid. Mean noise environment.
bertus
3,877
As I asked before, wich version of the PC817 are you using:
Also did you try a different resistor for the IR led of the PC817?
Also what is the value of R5 in your schematic (the collector resistor of the opto)?
Bertus
