Infinite Switch
Status
Not open for further replies.
Maharshi.pandya
Aug 31, 2018
Hello Everyone
Recently I just became a familiar with infinite control switch, I read it's manual and I found that it can operate up to 15 Amp. so if I want to use it for 30 Amp is there any available option. Moreover I did one solution I can use two infinite switch with one shaft just putting them back to back and customize their shaft. I am not sure it will work or nt. but I haven't check yet. is there anybody has any different idea please share it. that will really helpful for me. thanks
kellys_eye
Jun 25, 2010
6,512
No. The switch is bi-metallic and uses the heat from the current flow to open/close the contacts. In THEORY you could parallel them but unless they switched at IDENTICAL times one switch will end up carry all the current and be damaged.
Kabelsalat
Jul 5, 2011
198
Why not just not only parrallell them electrically, but also physically (if close and enough space around)?
This would be a good practice in Blender - but I'm not there yet.
kellys_eye
Jun 25, 2010
6,512
Physical distance between the contacts wouldn't make any difference. It's the contacts themselves that heat up (via the current flow) so they don't require to be 'touching' (or even near to each other).
Status
