V
Vector Viper
- Jan 1, 1970
- 0
1) Mistubishi CK3551R tv (1987; old!)
No power up, no response from remote or any buttons.
standby supply runs fine, caps replaced on both standby and main
supplies.
forcing set on with relay jumper gives a totally black screen (has
horiz+vert sweep+filament)
microprocessor getting +5 volts, and keyboard/remote signals ARE getting
to its
input pin. Relay output pin can work relay. Microprocessor seem stuck in
reset or brain dead?
cust says it worked int. before cut out. Any advice? I'm thinking service
manual now...
Does anyone have a pin-out/specs for a M50441-564sp micro?
Or on vs. off voltages on the connector "SA" on the video board?!
2) Sony 32" KV32XBR37 Chassis SCCF84VA
Came in dead, had the classic blown power regs (C4834)+blown output
(C4927)
Replaced all+the black vdr, found bad connection on 'E' of hor-out,
thought it fixed
after soldering everything....
Horout will now run MAYBE 1 min before blowing; gets hot pretty
fast....can't see pix
before this happens. Did sub a D1880 for hor out to get this
time;original
C4927 blows in SECONDS. For each horiz pulse at HOT, the trailing edge
is lifted off the
baseline (not sharp) tried swapping flybacks with a known good one with
no change.
disabling pincushion by pulling link coil WILL allow set to run with
bowed picture,
but HOT still gets too warm....What could the problem possily be?! bad
yoke???
The yoke is a 8-451-315-41. The hor winding measures 713uh on mine, if
someone has a listing
on specs for this part, let me know? I'm really stumped on this one...
Thanks for any help,
Aaron H.
supplies.
to its
manual now...
(C4927)
thought it fixed
time;original
is lifted off the
no change.
bowed picture,
yoke???
Aaron H.
