Input electronic signal to sound card input ?
boki
Dear All,
I want to implement a simple A/D conversion by PC sound card
input channel(Line in / MIC in), therefore I can employ it as a high
resolution A/D processor :D ?
What is the limit/problem in hardware?
Thank you very much for your comments.
Best regards,
Boki.
Rolavine
Dear All,
The net must be filled with informtaion about doing this, have you looked?
If you use the mic input it prob. has a dc voltage on it to power an electret
mic, so line in is a better choice. Either way the input with be ac coupled by
a series cap on the card. The line in should be good for about 300 mv rms input
(100mv is normal preamp out in hi fi). Any cheap card in a pc is noisy so you
prob. won't get as high a usable resolution as you might suspect. There are
some scope programs for PC's that use the sound card you should find one and
check it out to see the limits of this input.
Here is a link to a free sound card scope program on on the net,
I never used it
http://polly.phys.msu.su/~zeld/oscill.html
Rocky
I
Iwo Mergler
boki said:
Dear All,
Best regards,
Boki.
The soundcard input is a high pass at a few tens of
Hz. It doesn't work at DC and badly at low frequencies
(<~50Hz).
It's not as high resolution as you may think. 16 bit
is not really achievable inside a PC and most soundcards
are not even close, anything below the first 12 bits or
so is random numbers.
Otherwise it's possible and done quite regularily.
Iwo
Spajky
could be (if you can record music on pc, why not!)
max usable frequency response 20Hz-20KHz /around 95dB noise signal
ratio max for cheaper models like mine Ensonic AudioPci128 .... on
line input (150mV/47k); conversion 16-bit, 44,1kHz sampling ...
Mic input is Mono & in the midle ring on the stereo 3mm jack is that
phantom power; when used an ordinary mono jack, it shorts that, so on
the hot (input) you do not have any DC current!
not sure for line in ... (for Mic in for sure!)
There are
on mine there is at 19kHz -3dB drop which drastically increases
reaching frequencies above 20kHz; on the other hand there at low end
is same with drop @ 25Hz, but drop increases much much slower & you
can handle 10Hz @ -10dB drop & becomes unuseable lower than 5Hz!
I never used it
this I regularly use to make snapshots for my site´s electronics
articles .... for pics there I used for cards input only a resistors
voltage divider (trimmer pot.) ...
since I have an audio Led VU meter connected to my audio card & is
calibrated (has worse frequency ratio than the audio card), I could
approx. calculate signal drop at frequencies I stated for that audio
card...
Hope I helped ...
David Jordan
(<~50Hz).
It's maybe not as bad as you think... I tried an experiment a while
ago. Audition lets you zoom in on the amplitude scale and take very
accurate measurements of the signal level. I set a signal generator so
Audition read -6dB at 1kHz and swept the frequency while monitoring
the sig gen voltage with a 'scope to make sure it didn't change.
The table below is a listing of amplitude error (in dB) vs. frequency.
The two left hand columns are for a 'Soundblaster Live Platinum 5.1'
and the two right hand columns are for a Soundblaster USB widget I got
for about 30ukp.
Freq Right Left Right Left
10 -0.13 -0.13 -1.88 -1.88
20 -0.09 -0.09 -0.57 -0.58
40 -0.08 -0.08 -0.18 -0.18
70 -0.04 -0.04 -0.05 -0.06
100 +0.00 -0.01 +0.0 +0.0
200 +0.00 +0.01 +0.04 +0.04
400 +0.00 -0.01 +0.02 +0.01
700 +0.00 +0.00 +0.01 +0.01
1000 +0.00 +0.00 +0.0 +0.0
2000 -0.03 -0.02 -0.04 -0.04
3000 -0.09 -0.09 -0.06 -0.06
4000 -0.08 -0.08 -0.01 +0.0
5000 +0.02 +0.02 +0.02 +0.03
6000 +0.07 +0.07 -0.03 -0.01
7000 +0.08 +0.08 -0.08 -0.06
8000 -0.04 -0.04 -0.08 -0.05
9000 -0.10 -0.10 -0.02 +0.01
10000 -0.13 -0.13 -0.01 +0.03
12000 -0.01 -0.02 -0.12 -0.07
14000 +0.02 +0.01 -0.07 -0.02
16000 -0.11 -0.11 -0.20 -0.15
18000 -0.04 -0.05 -0.27 -0.24
20000 -0.54 -0.54 -0.92 -0.92
21000 -1.44 -1.59 -2.20 -2.20
22000 -3.8 -4.0 -8.60 -5.40
23000 -13.0 -9.0 -16.0 -12.5
24000 -23.0 -22.0 -24.0 -24.0
That looks pretty good to me! Notice the VERY sharp antialias filter
that starts at 20kHz.
This is true, I can see around 3 bits worth of noise - around 120uV. I
wonder about the 24bit Audigy devices, the are external so it would be
possible to get the noise down very low. I would hope to see >16bits
of resolution from one of these. They also sample at 192kHz but I
don't know if you still get the full 24bits of resolution at that
rate.
Dave.
