Insignia TV/VCR/DVD combo model NS-19RTR won't turn on
Brad
I have an Insignia TV/VCR/DVD combo model NS-19RTR (mfg 05/06)
in my repair shop that won't turn on. Note: I do not have a SM. This set was
turned off during a storm but a storm related power surge damaged it.
The main fuse is good. Raw B+ is 171V (aok), the regulated B+ measured
+43V which doesn't change when pressing the Power button. I also found
a +5V source and that was ok. There was no visual sign of damage (eg. burnt
component) anywhere. I tested several parts such as diodes, etc.
Has anyone repaired this or a similar model that was damaged by a power
surge?
Thanks in advance, Brad
Before you type your password, credit card number, etc.,
be sure there is no active keystroke logger (spyware) in your PC.
F
Franc Zabkar
surge?
Here is a site offering spare parts for your device:
http://bestbuy.partsearch.com/GetMo...orated&BrandName=Insignia&ModelNumber=NS19RTR
Typing "FBT" into the search box produces a part number of
LTF00CPXB048 for a "TRANS FBT JF0501-3201A-G".
FWIW, a Google search for LTF00CPXB048 then finds a Funai 6719DG
(Sylvania) 19" colour TV/VCR/DVD.
Searching for "vertical" in Best Buy's database produces
"QSBBA0SSY003" and "VERTICAL OUTPUT IC LA78040A".
A search with Google on ...
"QSBBA0SSY003" filetype:pdf
.... then finds ...
http://electronics.vinu.edu/eresources/2008.pdf
http://electronics.vinu.edu/eresources/2007TV2.pdf
http://forum-files2.fobby.net/0004/5937/SYLVANIA 6420FE.pdf
It may be that one or more of the above PDFs has a similar PSU
circuit. If not, then you could repeat the procedure for other major
ICs, eg the jungle IC.
- Franc Zabkar
F
Franc Zabkar
I suggest that the OP saves the "View as HTML" version of the service
manual (the PDF link is dead) before it expires from Google's cache.
- Franc Zabkar
F
Franc Zabkar
The Best Buy parts site suggested that other models using the same FBT
as the Insignia NS-19RTR are the Funai 6720FDG and the Funai
MWC20T6/TV.
Service Manuals:
http://www.funai-corp.com/6pdf/sm/6719DG.pdf
http://www.funai-corp.com/6pdf/sm/6720FDG.pdf
http://www.funai-corp.com/6pdf/sm/MWC20T6.pdf
Owner's Manuals:
http://www.funai-corp.com/6pdf/om/6719DG.pdf
http://www.funai-corp.com/6pdf/om/MWC20T6.pdf
http://www.sylvaniaconsumerelectronics.com/pdf/om/6720FDG.pdf
http://www.funai-corp.com/6pdf/om/6720FDG.pdf
- Franc Zabkar
