Installed Farming Simulator on the PC, but it does not launch
Lioness
Apr 19, 2023
5
Hi everyone.
Does anyone on this forum play Farming Simulator 2022?
Need your help. Decided to buy this game on PC.
Before that I played it on my smartphone.
Bought it on the official site. Installed it and it won't launch. Falls out with 0xc000007b error. Maybe someone has run into this and can help? Thank you all for the answers.
Alexixx
Apr 1, 2023
9
Most likely you have a problem with DirectX. It is not installed (you need to download and install it), or there is a problem with this library. In this case, too, reinstallation will help.
Try to do what I wrote above. If that doesn't help, you can use the instructions at https://fs22-mods.info/farming-simulator-2022-does-not-launch-or-crashes-troubleshooting/. In brief, you need to find a file game.xml, open it through a text editor and replace there the line renderer>D3D_12 on renderer>D3D_11. That should help. Usually this file is in the folder with the game.
Lioness
Apr 19, 2023
5
Thanks, I'll use your advice when I get to the computer tonight.
KillerInstinkt
Apr 29, 2023
Hello! Try to go to the game folder C:/Users//Documents/My Games/FarmingSimulator2022 and delete the folder called Shader Cache.
You can also try opening the game shortcut as an administrator.
Also be sure to install the latest Windows updates, if available. This may fix some bugs with DirectX, Visual C++ and Net.Framework libraries.
