I played some Civ 3 Conquest which is CPU intensive... and I noticed the
motherboard temperature actually rises.
I must also come to the conclusion that AMD's Cool & quiet is actually Hot &
Quiet !
I have decided to turn off:
1. Cool N Quiet in bios.
2. Asus Q-Fan control
3. AMD's Power Monitor.
To keep the CPU and motherboard COOL !
The noise level has slighty increased, but probably not as bad as my old
computer... so it will have to do.
It makes a hell of difference to the temperature !
The CPU is already 7 degrees cooler !
The motherboard is 1 to 2 degree cooler !
According to Asus Probe II.
I will continue monitoring it a bit... but I am think having a little cooler
cpu and motherboard seems smart
Hopefully the new motherboard will now last longer than 1 year and 3 months.
Also the constant fluctuations of voltage within the cpu and logically
outside because of savings might also play a role in damage.
Actually I might even go into the bios and set the cpu voltage at 1.1 volts
so that it runs at 1000 mhz per core...
But that probably not necessary anymore... because the fans are already
spinning at maximum.
So no need to comprise system speed...
Though running the cpu at lower speed would probaby reduce the heat some
more... and the fans still spinning at maximum so overall heat should go
further down
So that's still an option for the future.
Most games and apps probably don't need more cpu power than 2.0 ghz
anyway... but ok..
I am not sure which bios setting I would have to change... maybe vcore.. or
maybe frequency...
So I am still doubting if I should lower cpu speed.
I am scared shitless my motherboard will die again
Bye,
Skybuck.
