interesting thing about oscilloscope at different SEC/DIV
Chengjun Li
Oct 21, 2014
84
I use oscilloscope to measure a 1000Hz 6Vpp AC signal. I observed different traces shown on the oscilloscope screen which is interesting.
When sec/div is 1ms,
When sec/div is 5ms,
When sec/div is 100ms,
When sec/div is 250ms.
When the sec/div is 50s,
Observation:
1.As you can see, as sec/div changed from 1ms to 5ms, the screen showed more cycles, which is the common sense.
2.When the sec/div is increased to 100ms, more cycles were shown on the screen, but the oscilloscope changes to scan mode.
3.But when the sec/div is increased to 250ms, the oscilloscope couldn't show the true input signal.
4.As the sec/div increased to 50s, what the oscilloscope shown is the same amplitude with the input signal but different frequency.
I have two questions,
1. when the sec/div is increased to certain value, why the oscilloscope change to scan mode?
2. what's the reason of above observation 3 and 4?
Thanks.
Gryd3
Jun 25, 2014
4,098
Observation:
Thanks.
What waveform are you vieweing, and can you change the frequency to something slightly different.
I suspect, that it's merely a fluke in that the samples being taken just so happen to line up to appear to be a different waveform. Changing the frequency you are observing will show a drastic change in observations 3 and 4.
Chengjun Li
Oct 21, 2014
84
I did the thing as you said and did observe different waveform for 500ms.
For 800Hz,
For 15kHz,
I also test other frequency, but I didn't show it here.
However, for sec/div is 50s, I could always get the right amplitude but wrong frequency.
For 800Hz,
For 15kHz,
I think you are right, it is about sampling.
