We don't know what is exactly you want to know .
If your 8051 system want to connect with the 12V system,you should use the 12V power supply and the low down the Voltage to 5V for 8051 system.
and you the relay is used in the 8051 system,you can select the 5V relay or 12V relay ,that is depended on what you want .
1.Extract the code for you from programed Mcu for legal use
2.Specilized in the Microwave sensor,automatic door sensor,infrared sensor
3.OEM PCB and design for you in China
www.wafersensor.com
[email protected]
