Intermittent static when viewing cable, cable ready problem?
I swapped in a different tv. I did not carry the 31" downstairs. The
new set did not have any static at any time.
I tried what electricitym man suggested: reconnecting the old tv and
using the vcr tuner. And experienced 2+ days of no static whatsoever.
But the static has returned. To be very clear the connection is
wall-digital box-vcr (vcr on, vcr on vcr not tv, set to channel 4)-tv
channel 4. And I am using coaxial cable all the way trough. I believe
electricitym had intended that I use the composite output from the vcr
and bypass the tv's coax/tuner completely. I will do that as a last
resort but the tv is a bit older and only has coax and
s-video/composite inputs.
I will next try to open the unit and inspect grounds and soder joints.
I won't be able to get to it until sunday, thanks to everyone for their
input.
DC
Mark
if you know what the tuner looks like, and you are not an expert,
don't open the tuner...just squeeze the cover of the tuner a few times
and see if that fixes the problem for a few weeks,,, if it does then
you know you need to get a tech to open the tuner and clean the ground
contacts to the cover...
Mark
Gene E. Bloch
Damm that hurts doesn't it!....
It is definitely not fun. I've also gotten too close to spark plug
wires. That should be avoided too.
I guess if I had continued to make a habit of it, my nickname would be
Sparky instead of Gino :)
Sp...I mean Gino
