Internal wiring of USA v UK mains plug
Spurious Response
It takes the same amount of energy to boil a quantity of water whether
you're using a 1 kW or 3 kW kettle. Infact it would probably take less
energy with the 3kW kettle as it gets the job done quicker, which
means less losses.
You also have to account for losses at the kettle itself. They do not
transfer 100% of the energy, and the higher wattage units radiate a lot
more, so they are slightly lossy-er.
I'll stick with my infinitely (FAIAP) variable gas, thanks.
Spurious Response
Not an appliance, and in Sweden, not Japan, but I have...
It was quite obvious that I was not asking you about you.
Spurious Response
Apart from the fact that the energy used in a more powerful kettle is
slightly less, the rates in California appear to be about 12-15c/kWhr,
compared with my UK rate of 9p (~18c). The big difference in costs here
is that the climate is such that we don't need (and most of us don't
have) air- conditioning.
Paul Burke
I do not have, nor do I need AC here, near the shore. Inland becomes a
different story.
W
Wolfi
Am 03.07.07 19.58 schrieb Spurious Response:
If you are plugging some bent up plug into a power socket, you are an
idiot for not servicing the plug before using the product it was attached
to. Oh, and if you are seeing perfectly normal plugs coming out of an
outlet, YOU need to service the outlet.
I never said, that the compressor plug was bent at all. It is still in
original condition, so is the power outlet as well.
But it is mounted to a column inside a shop at about 1.20m height and the
shitty power connector system just isn't capable of supporting the relatively
thick, rubber insulated cables weight until it hits the floor, without letting
the plug slip out over time, until at least one spade starts losing contact.
As an additional hint: in this case, the ground pin is at the bottom, the 2
spades on top.
I'm simply reporting first hand experiences with the U.S. system, and compare
them to others with connector systems, where the removable part dives with its
housing into the receptacle to some degree.
John Larkin
spades on top.
For serious stuff, use a twist-lok.
John
Michael A. Terrell
spades on top.
Firsthand experience of someone who is unable to anchor a heavy cord?
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
Thomas Tornblom
So where does the energy that is not transfered go?
Radiant heat losses is exactly why a more powerful kettle would
consume *less*. It gets the job done quicker and the time it will
radiate heat is shorter, which makes it more efficient.
Dave Plowman (News)
Where does the 'spare' energy go? Pretty well all of the energy is
transferred to the water. Of course a lack of insulation means some of
this is wasted.
A gas burner definitely doesn't transmit 100% of the energy to the water.
I'd say you've no experience of a 3kW electric kettle. They boil faster
than using a gas ring and of course cut off automatically. Gas also
produces moisture as it burns so makes more mess in the kitchen.
Paul Burke
Work it out. The element is entirely surrounded by the water you want to
heat. So all the energy, apart from that conducted bak into the cable,
passes into the water. Most electric kettles these days are plastic, so
not much gets throgh the sides. Rather more escapes through the top,
especially while the kettle is actually boiling- I use this energy to
preheat the teapot. So efficiency is pretty good. A more powerful kettle
is better because there is less heat lost through the top and sides when
you are heating it.
As for gas, most of the energy simply wafts round the outside of the
kettle, and never heats the water at all- it just heats the universe.
Which isn't to say that it's not generally the best way to cook.
Paul Burke
Paul Burke
John said:
We pay a sliding scale for electricity here in San Francisco, from
about 10 cents to as much as 22, nonlinear on consumption, to
encourage saving
Oy! It's the other way round here, you pay 22p/kWhr for the first N
units, then about 15p thereafter. It's supposed to cover fixed costs
like the meter (which was there years ago and must have payed for itself
many times over at that rate).
Spehro Pefhany
this is wasted.
Modern auto-shutoff 'cordless' electric kettles are a great
convenience.
Best regards,
Spehro Pefhany
John Larkin
"P" is pence? Roughly 44 cents/kwh? Yikes!
Our low rate is called the "lifeline" rate, for poor people who
presumably need a modest amount of power to get along.
The great thing about this climate - chilly all the time - is that we
don't worry much about wasting gas or electricity: it all goes to heat
the house. What I really should do is arrange to recover some of the
heat in wastewater, like an outgoing/incoming heat exchanger or
something. The water comes in ice-cold.
It's going to be hot here today: 8 AM, and it's already 60F, and the
fog is burning off.
John
Robert Latest
["Followup-To:" header set to sci.electronics.design.]
something.
The house we're building is going to have that not for water, but for air
(outgoing warm air heats up the incoming air in a heat exchanger). This
makes a difference only in extremely well-insulated houses though.
robert
Spurious Response
heat.
Only foil coil immersion types. Our "kettles" over here have enclosed
heating elements under the kettle, so it would lose a bunch.
Immersion heating elements are about as efficient as one can get.
We used to place a few coiled rubber bands between two spoons, and hook
'em up, and that would boil water pretty quick too.
Gives "Direct Current" a new meaning.
Most "plastics" that can handle those temperatures also conduct heat
pretty well.
Stick a lid on it. Once the water is boiling, one can reduce heat and
retain boil, another good reason for gas.
I love finding uses for wafting, otherwise wasted heat.
you are heating it.
A smaller "vat" has less exposed surface area, and is quite valid to
consider as a spoiler to your claim. It all comes down to using the right
heated pot for any given volume considered.
Why do you think solder pots are short and squat, and not some eight or
ten inch diameter device? It isn't just the handling issues. It has a
lot to do with conservation.
kettle,
When I put water on to boil, I start with *very* low heat, and most of
it hits the mark, and that which wafts, heats those same sides. The
flame barely leaves the burner head, and the gas meter barely moves, and
I boil water much better with a long slow process than a "stick a torch
to it and GO" method, so not much "spills" up the sides.
I am very lean on consumption. My carbon footprint barely exists at
all. Been riding a bike to and from work for the last twelve years.
Gas is definitely the best, most controlled application of heat,
therefore is the best way to cook.
I wish microwave ovens were wattage controlled, instead of duty cycle
controlled. I would have many more uses for it then. Still, it is my
second choice. Electric burner stoves, and cooking accessories are the
most wasteful use of juice there is. The only proper electric stove
would have skillets, pots, and pans with integrated elements in them.
Otherwise there is a lot of loss with electrics as well. I'll take gas
any day.
Riscy
means less losses.
Agreed, but you can't really save on a kettle, unless you switch to
some alternate energy source.
Not an appliance, and in Sweden, not Japan, but I have lowered my
hosehold energy consumption from 40+ MWh annually to around 18 by
converting from direct electrical heating to a rock heat pump, and
paying attention to the consumption of appliances.
I have a 200 m drilled collector in my back yard that feeds the heat
pump. The collector is also used as a source (drain?) for cooling in
the summer. One only needs to pump the +8° brine coming from the
collector through a few convectors, no need to run any compressor.
I'm currently installing the air conditioning parts of the system,
which when finished will provide about 10 kW of cooling power for about
300 W of input power to run a brine pump and the fans in the
convectors. Theoretically it will also warm up the collector slightly,
which improves winter operation, but that is marginal, if any.
Oh, and while were talking about electrical systems, domestic feeds in
Sweden are almost universally 400V three phase.
My main fuses are 25A. When we bought the house in 1987 it had 20A
fuses, and electrical heating. One of the main fuses would
occasionally trip in the winter when the washer and stove was used,
while the radiators were running on full blast. Switching to 25A fuses
solved that. After the heatpump conversion I can most likely go back
to 20A fuses and save some on the electrical bill.
When we bought the house, the stove, washer, dryer, boiler and sauna
were all wired for three phase 400V operation. The radiators were 400V
two phase. The new washer and dryer are single phase 230V units, and
we've ripped out the sauna and the heatpump produces the hot water, so
the stove and heatpump are the only remaining three phase consumers.
Hi
I'm thinking of heat pump system at my home.
How big is your house, what is the heat demand and size of the heat
pump and who make them, was is NIBE.
It seem you have passive cooling and active heating arrangement. This
is very good arrangement because it much cheaper to cool house via
ground source.
Was is possible to email me the design plan of the system and the
calculation?
Richard Payne.
Riscy
How would going to 20A fuses save some on the electric bill?
bz 73 de N5BZ k
please pardon my infinite ignorance, the set-of-things-I-do-not-know is an
infinite set.
[email protected] remove ch100-5 to avoid spam trap
Because the heating system now driven by ground source heat pump
system, which take 3-4 time less power for same amount of heat. This
is a key feature and will reduce electric bill by 3-4 time, cheaper
than gas heater.
You no longer requires 25A and hence reduces to 20A as orginal circuit
design limits may allows. You may risk damage to cable and connection
if you keep 25A fuse.
Eeyore
than gas heater.
Unfortunately in the UK, electricity costs ~ 3 times more than electricity per
kWh so the efficiency of heat pumps saves you no money on your heating bill here
if you have gas available.
Graham
Dave Plowman (News)
So where is it lost to? BTW I've never seen a kettle where the element
isn't in the water.
pretty well.
Eh? Most plastics are poor conductors of heat.
If you're there to reduce the heat, why not simply use the boiling water?
right heated pot for any given volume considered.
Never seen a 'jug' kettle? Not much use with gas, though.
Good grief. Most just want that cup of tea *now*.
You don't cook with a kettle. Well most don't.
Integrated elements would have to be covered at all times. The only other
appliance where this makes sense is a deep fat frier.
any day.
In the UK most use gas for the hob and electricity for the oven. But
pretty well all use an electric kettle for boiling water. The reason being
we've always had a 3 kW kitchen electrical socket.
