Eeyore
- Jan 1, 1970
- 0
Gary said:Not really needed, but could be a hazard due to mis-fusing.
Hardly any more of a hazard than an unfused plug !
Graham
As to wire-nuts, what would you propose?
DJ said:Here's the one I use:
http://www.quail.com/nema.cfm
But yeah, TWO types of outlets? Come on, my house has way more than
just TWO types. Heck, I have at least two types of just 120v outlets.
Eeyore said:Why would you need more than one type ?
Most of them are the usual 15 amp outlets (||). Some (in my workshop)
are 15/20 outlets, with the extra slot for 20A-only cords(+|). I have
one 30A twist-lock outlet in my generator, too.
I don't think I've ever seen the 20A-only plug on anything though.
Have they gone the way of the $2 bill?
Two-prong receptacles may be replaced by three-prong as long as there[email protected] (Geoffrey S. Mendelson) wrote in
In new installations maybe. There are still many hundreds of thousands of
two prong recepticals still installed, or incorectly refitted to three
prong recepticals.
krw said:They're still around too. ;-)
I'd like to see some supporting data for that litle outburst.
Dave Plowman (News) said:If like UK wiring of that age, rubberised cloth. Which crumbles away. Uk
wiring was often lead sheathed and inside the sheath the insulation can be
perfect. But the ends exposed to air etc not.
*If only you'd use your powers for good instead of evil.
Dave Plowman [email protected] London SW
To e-mail, change noise into sound.
Rich Grise said:
The lead was the earthing conductor and at most points, of a tight bend,
the lead would fail a few years after the bending at installation.
Also there are 2 very similar types of 2 pin plug which sometimes
causes confusion. The modern EU ones cant fit a UK socket, the pins
are too fat and too closely spaced. Forcing doesnt work. There are
also historic French plugs that look similar and do fit our sockets
with a bit of fiddling, but very rarely does one see one of those used
over here. They have 4mm pins. I dont think I've seen one in over 20
years.
Eeyore said:I'd like to see some supporting data for that litle outburst.
Geoffrey S. Mendelson said:As late as the 1960's London had FOUR different electrical systems with
different voltages and plugs.
As late as 1989 I bought a clock radio
in London that did not have a plug on it. You had to buy one that
matched your outlets.
As lightbulbs were mostly the same size around the world a friend of
mine who traveled, carried an adapator that screwed into a lamp
socket and had a standard U.S. outlet instead of the bulb.
I have one that is like that but it has another lamp socket
on the top and two "euro" two pin outlets. I assume that they
are highly illegal in the U.K. now.
I'd be very surprised about that. I can only think of 2 different plug
standards. What's your source ?
Dave Plowman (News) said:Are you sure about that? There were several different socket outlets still
in use - 3, 5 and 15 amp all in either two or three pin.
Dave Plowman (News) said:Eh? Even with final circuit rings there were at least three types of
sockets. Normal, D&S (round pins where the live was a removable fuse) and
Walsall gauge. Same as 13 amp but the pins at 90 degrees. The last two
often used by councils on housing estates. Gawd knows why. Some official
with a bee in his bonnet. Or saving pennies.
Then plenty of the old types still in use. 3,5 and 15 amp round pin. In
both 2 and three pin. Then there were some oddities with flat pins.
No, he IS saying it is in use. Some of it has been replaced, but not
all of it.
