Internal wiring of USA v UK mains plug
John Larkin
You're not saying there is 100 year old wiring still in use?
My previous house, a Victorian built in 1892, had gas pipes leading to
all the lighting fixtures, capped off, and exposed knob-and-tube
wiring in the attic. Junctions were twisted and taped, hanging in
mid-air. I assume the original wiring was intended for lighting, and
over the years, as more loads were added, it became less suited. I had
a few joints open up, and eventually rewired it with Romex, with all
joints inside proper metal junction boxes. There's still a lot of
ancient fabric-insulated, twisted-junction knob-and-tube stuff around.
http://www.oldhouseweb.com/stories/Detailed/10327.shtml
http://www.knobandtubewiring.com/knob and tube.gif
It's common to see a fuse box, designed for 5 or 10-amp screw-in
fuses, to be full of 30's.
Around here, knob-and-tube was succeded by mandatory rigid steel
conduit and later, roughly 1960 maybe, Romex. Commercial buildings
must still use conduit, rigid metal pipe or the flexible MX stuff.
There is no requirement that old construction be upgraded, unless a
major remodel is done.
John
jakdedert
krw said:
There are also outlets used for room air conditioners. I have a 120V
15/20A outlet by one window downstairs and a 240V 20A (IIRC) outlet
for the thru-the-wall AC. Stoves and clothes dryers may also have
either a three pin ungrounded or four pin grounded outlet.
In addition, there are at least a couple of different 240v outlets used
for clothes dryers. In fact that's one appliance commonly supplied
'minus' a cord...the appropriate one being fitted at time of installation.
jak
jakdedert
John said:
They are about the same as the IEC connector on the other end of most
power cords. No big deal.
Physically, perhaps, but inasmuch as the IEC connector is a temporary
connection (and user replaceable), and the Edison is supposed to be
permanent...not the same at all.
I think that the number of deaths from US-style outlets is minute.
Electrocution and electrical fires result mostly from bad/old house
wiring and faulty appliances.
Electrocution rarely if ever results from a faulty connection, although
the Edison plug design is prone to tampering and accidental shock hazard
by children. It's possible to partially insert the plug and little
fingers to get on the exposed--but energized--prongs.
Germany runs about 1 PPM annual risk of death from electrocution, with
the USA closer to 2 PPM. That's not a lot of risk. I recall reading
that the majority of electrocutions in the US are on construction
sites, things like machines and ladders hitting high-voltage lines.
Perhaps you're referring back to an earlier part of the thread, but
there is nothing in this post about electrocution. Rereading the above,
it is about the propensity of the common Edison socket to wear out and
cause intermittent connections.
FIRE hazard, not electrocution.....
Really, cars are hundreds of times more dangerous than electricity,
and cigarettes 10x again. If Europeans want to save lives, they should
discourage smoking.
Those hazards are being addressed. What does the above have to do with
the shortcomings of American Edison sockets?
jak
In the US, we know better than to do stupid crap like plugging in live
equipment.
Good Luck!
Rich
Are you really saying no-one ever unplugs things withoutout turning
them off first? I really doubt it.
NT
James Sweet
Gary Tait said:
[email protected] wrote in @n2g2000hse.googlegroups.com:
Some equipment simply has no off switch..
Who cares? I unplug and plug in items that are turned on all the time, worst
case you get a little spark, it doesn't cause any problems. It's not hot
enough to pit the plug prongs or contacts.
Tam/WB2TT
I really can't recall reading about anybody being electrocuted inside a
house. I do recall a case involving a swimming pool. Typically, someone
manages to get across a 2.4 KV line; there one of three things that will
happens: 1 - you get bad burns and live, 2 - you fall off the ladder and die
of the fall, 3 - you die of the electrocution. Probably the worst case is
somebody holding on to an aluminum ladder with both hands that comes in
contact with an electric wire. Your chances of being electrocuted due to
casual contact with a 120 line are pretty much nil.
Tam
John Larkin
That might generate a tickle. The geometry is very unlikely to be
lethal. Chewing on cords, especially by pets, is a more serious
hazard, and 240 is a lot worse than 120 there.
I don't have access to the statistics, but I really doubt that the
American plug/socket combo is a significant source of fires.
John
Robert Latest
["Followup-To:" header set to sci.electronics.design.]
discourage smoking.
All European countries want to, with the quite influential exception of
Germany. I seem to remember having read that Germany was the world's biggest
cigarette exporter. That and some EUR 14b annual tobacco tax income say
progress is going to be slow, but there is some.
robert
b
may not seem so at first, but this will damage the contacts and lead
to the formation of carbonised areas. And more noticeable stateside
what with the limited 'actual' contact area between the US plugs and
sockets - I would avoid plugging in or removing plugs of live
equipment for reliability reasons.
-B
Its well known that repeated small sparks make a total mess of the
contact surface. This was one of the problems of our olf round pin
system half a century ago.
NT
Dont think I've ever seen pet chewed cords here, maybe different
checmicals get used in the plastic or something.
120 0r 240 would kill either way.
John
http://ieeexplore.ieee.org/xpl/freeabs_all.jsp?arnumber=148498
NT
John Larkin
My cats love our Apple products, which have soft vinyl cords. They
won't touch my Intel-based systems. Smart cats, no?
240 is much more likely to kill.
It's not clear that the paper is relevant, and I'm not going to buy it
to find out. Having designed equipment with, likely, a few million
1-amp-and-up connections, and no meltdowns much less fires so far, I'm
skeptical. And a US electrical plug is hardly "a current-carrying
loose copper wire connection."
John
Dave Plowman (News)
You'd have to explain that. Most of the old round pin sockets were
switched - unswitched was a short lived fashion with 13 amp stuff. At
least in my experience.
The old round pin sockets were far more likely to be overloaded, though.
jakdedert
bz said:
If an earth ground is not available, a GFI outlet should be installed at
the beginning of the run and 3 prong outlets along the rest of the run.
The GFI will trip if a ground fault is present.
The outlets should be marked to indicate that a GFI is installed and that
no earth ground is present.
I believe that this is much safer than using 2 prong outlets and meets
code.
Yes it is, and I'm perfectly aware of the fact. OTOH, replacing with
original equipment is far more responsible than doing what most people
do: replacing with a three prong outlet and either leaving the ground to
float...or worse yet, bonding ground to neutral.
Eventually, all those two-blade outlets will be rewired properly, with
new circuits added. I've done about 25% of the house so far, but it's
slow going....
jak
jak
Spurious Response
It is also well known that the properly designed flat blade has a nose
which has sharp enough corners to be the spark point for any arcs. That
means they will all begin or end along those edges, and along the "lead
in" faces of the receptacle. This means that the swept surfaces that
make up the "contact area" of the blades and socket terminals during use
will always be in fine shape.
Our plugs are designed to handle tens of thousands of "hot insertions"
like this. It has to handle some specific number at full rated current
as well. It is part of the design spec for the outlet. This is also why
the ground pin on 3 wire setups is slightly longer. It "makes" contact
before the other "pins" (blades).
Spurious Response
NT
Small dogs chew cords. Rabbits certainly do.
With the short electrical path involved, unless the dog/rabbit was
laying on a concrete floor (I have seen this happen) in a
moist/conductive condition, the jolt would likely only teach the lesson
of what not to chew on.
Spurious Response
Having seen plenty of badly bent contact blades on vacuum, TV set, computer &
monitor, power drill and other shop devices' power cords, I strongly disagree.
What part of "if one remains within the specs for their use..." do you
not understand?
Spurious Response
All three pins on the other end of an IEC power cord are flat blades.
John
Yes. Thick, flat blades. Leaning toward square even, but not quite so.
The main reason is that the designers of that chassis end (entry
module) of that chassis connector system wanted large, round nosed
pyramidal points on those strong, flat blades so they could act as good,
repeatable "lead-ins" for the "otherwise only held in by the rubber
squeeze" connector. Also, flat blades do maintain larger swept area of
contact (and therefore safer current carrying capacity) longer than pins
and sleeves after repeated disconnect reconnect cycles. That plug design
was meant for molded on plug assemblies.
Jeez, just think of how huge some strain relieved, metallic, heavy duty
device would be on the back of all our gear over the years.
That was one more benefit of the flat bladed design, was narrower
overall plug size for any given ampacity and voltage compared to what
would have been required for round pins.
bz
slow going....
Understood. I spent quite a bit of time putting GFI's in a house we bought
and are renting out. It was built in the late 40's and expanded several
times, some grounded outlets were installed but grounds were missing on
several. Older parts of the house are on an aux breaker box.
Figuring out what fed what was fun.
bz
please pardon my infinite ignorance, the set-of-things-I-do-not-know is an
infinite set.
[email protected] remove ch100-5 to avoid spam trap
