Ion Pathfinder 2 power wire colar
Sling8749
May 30, 2023
Witch wires are positive and negative on the power supply on a ion Pathfinder 2porterbal blue tooth speaker
Delta Prime
Jul 29, 2020
2,996
This witch is positive you tell by the stockings
This witch is negative you tell by the green
Help me help you or I'll cast a spell on you too!! photos please!
kellys_eye
Jun 25, 2010
6,512
Difficult to tell without a picture. Quite often the wires (if they are a pair) have a marking line on one of the cores that signifies positive - but sometimes it signifies negative!
If there is a plug fitted (with a barrel connector) the outer part is usually negative, the inner part positive - but again, this isn't always true!
The only SURE way to check is to use a test meter.
