iphone charger and synchronize
elektronik
Sep 20, 2013
10
Heyyyy
I have made a small charger for iphones and other phones, but I have a problem with letting them synchronize with the pc.
the charger takes currents from the usb of my pc. The question is how to make the iphone for example synchronizing with the pc while charging?​
You connect up the USB data pins and you load iTunes.
Heyyyy
In other words, you have made a cable, which most people have 20 of scattered around the house by now, except you left off the data lines.
elektronik
Sep 20, 2013
10
What I did is, I connected D+ and D- to some resistors to get the 2,7 volts on these pins, else the iphone 4s won´t charge!!
I also want to connect SD card to it therfore Im asking how to still use data pins to transfer data between the pc and iphone.
in which way???
First I need to get 2,7 V or something like that on the two data pins.
You only need that if it's not hooked up to a computer.
If it is, it will talk to the computer and draw up to 500mA.
I would be pretty certain you can't get it to draw more than 500mA *AND* talk to the computer.
elektronik
Sep 20, 2013
10
SO you mean, I just connect it as usual?
I tried that, the iphone doesnt charge!
Only when I apply the 2 volts and still connect it to the pc.
Imagine it like a normal iphone cable but there is a LED and sd card connected to the wire while the lightning goes to the iphone.
Schematic will look like:
pin 1) 5+
pin 2) D+ = 2V
pin 3) D- = 2 V
pin 4) GND
14,317
How do you connect an SD card to a USB cable?
What do you mean by "lightning goes to the iphone"? In which way is the LED related to charging the iPhone?
elektronik
Sep 20, 2013
10
by mounting a micro usb sd card holder to the usb comming from the pc. So I have a female micro usb which is used for the Micro SD.
lightning connector for the iphone will be connected to iphone as normal.
The LED should light when the charger connects to the usb of the pc.
Sorry for the bad english, its may be me who writes in terrible way
14,487
lightning connector ??? never heard of it
still have no idea what you are talking about
14,317
You cannot connect two devices to one USB port. The SD card reader has to use a different port than the iPhone.
14,487
yes so the computer only saw either the iPhone or the SD card
but with a hub you could have them both connected at the same time
elektronik
Sep 20, 2013
10
How small can the hub be?
Becasue I will not carry a 1/2 kg thing with me
14,487
google USB hub
PLEASE do so investigating for yourself
these things are very common and easy to buy
14,317
Or use two USB ports of your computer - it surely has more than one, does it?
elektronik
Sep 20, 2013
10
It has, but when ever you think to make a small component, it has to be a little multitasking.
Best idea now to make a switch.
Thank you guys
