IR Lamp
stuee
May 7, 2004
183
I have a 7 bar ir lamp about 5cm|X30cm unit, its rated at 400w/230v
how would be the safest way to connect it to the mains using a plug and a inline switch, also i want it fused too.
audioguru2
Apr 6, 2004
12,026
Hi Stuee,
Just hook-up that heat-lamp then stay away from it.
It will "cook" you and give a nasty sunburn.
ante1
Jan 24, 2004
4,138
You can use a 3A fuse if your socket is unfused.
stuee
May 7, 2004
183
i dont want it for cooking:)
I want it for a heater to dry spray paint between coats.
is there any way i can put a varible switch for power to it, to its not just off or toast?
ante1
Jan 24, 2004
4,138
I should work with a triac circuit to control it I think.
ante1
Jan 24, 2004
4,138
Audioguru,
BTW. I believe it is UV light not IR that gives you tan??
audioguru2
Apr 6, 2004
12,026
Hi Ante,
You are correct, UV gives a tan. But maybe burns you too.
The intense heat from a IR lamp definately will burn you, and dry paint too.
Yeah, an ordinary light dimmer will control its heat.
