Beerbarian
- Jan 1, 1970
- 0
I have a Mitsubishi Black Diamond DVD player (BD30DVD) which works
fine but it's IR remote control seems to drain batteries quite rapidly
over time, while not in use.
I first suspected the cause was dud batteries bundled with the device,
but I have since gone through a few packs of premium brand alkaline
AAA batteries, and the same effect is seen with each fresh battery
change: the remote drains the batteries while lying in a drawer not in
use.
I've made sure nothing is lying on top of it to prevent having one or
more buttons kept accidentally pressed, yet after about a period of
about 2 months on non-use, the remotes two AAA batteries are dead.
The player and remote are about 18 months year old, and have very
little use.
I'd say I've used it about 6 or 7 times previously, but got gifts of
DVD's for Christmas and now am anxious to get watching without going
out to the shops to get more batteries every time! (some functions are
only available on the remote)
I've dug out the multimeter and dismantled the IR remote to try my
hand at some fault finding, and was hoping one of you fine folks might
give me some pointers as where to begin?
I won't go into component specifics just yet, suffice to say the
circuit is quite simple, although the workmanship on the factory
soldering looks very poor, and already appears to have a bridge wire
from one track to another, but no obvious shorts.
I'm just looking for tips on tracing the constant voltage drain, if
that's not being too simplistic from my description.
At the moment I'm removing the batteries each time I put it away, but
the delicate battery covers lock tab has already snapped because of
the constant use it's got, and I was think if fitting a slider switch
to give on/off to the device, but I'd really like to get to the root
cause if I can.
Thanks for taking the time to read.
Éanna
use.
little use.
cause if I can.
Éanna
