SampleBandit
- Jan 1, 1970
- 0
Howdy all,
I am building a simple tv remote jammer using the simple 555 timer
chip. I don't want to get as extreme as a microcontroller. I have done
various testing with duty cycles and frequencies. I can easily make it
tunable within the 36-40khz range. The particular tv target I am after
is a magnavox using RC5 at 36khz. I went to RadioShaft and got 2 of
the following IR Led: Specifications for the 276-143C are as follows:
• Radiant Intensity (mw) 7.368
• Peak Wavelength (nm) 940
• Forward Voltage (V) 1.28
• Half View Angle (Degrees) 36.36
I have sucessfully jammed the tv as long as my circuit is 6 foot away
from the tv. My present circuit setup uses 2 individual 2n2222a NPNs
each driving 1 IR Led on the collector side. I have experimented with
current limit resistor down to 47 ohms and the IR Leds were just
slighly warm. I am sure that this is not necessary and there is a more
effieicnt way.
Now, the age old problem. How to make the range as efficient as the tv
remote itself. I find it hard to believe that my circuit powered by a
9 volt battery cannot overcome the signal from the 3 volt powered tv
remote. I have experimented with shorter pulse duty cycle as well as
50% (or as close as the 555 can do), PNP vs. NPN transistors, IR Leds
in series on 1 transistor, collecor and emmiter led connections.
So what can one do to increase jamming range? I have read that making
the duty cycle of the pulse shorter makes the IR led transmit further.
I didnt have any luck. lso this make me wonder how the receiver calcs
the frequency. From rising edge trising edge? The newer tv remote
circuits may be much better at rejecting noise but if I have been
successful at 6 feet then I should be at a longer range.
I have thought of the issue of IR Led transmission scope. The ones I
bought from RadioShaft are 36 degrees. I am using 2 of them and should
be able to cover some ground without a focusing lens. My tv remote has
2 and no focus lens. How do they do it?
Is a 50% duty cycle
necessary? Do I need to be more precise then a 555 timer? I have been
to many web sites and read many newgroup postings but this
issue seems to be the search for the IR Holy Grail! I would like to
keep it simple.
I now call upon you IR wizards for help
effieicnt way.
keep it simple.
