Is a USB to GPIB dongle/convertor a difficult project ?
robb
That is something like the Prologix USB to GPIB
convertor/controller ?
Is this a USB/GPIB IC chip and connectors or is there more to it
Thanks for any ideas
ROB
Richard Henry
ROB
You will need at least some buffering memory to resolve timing
differences and some logic to resolve commands. I assume your device
will look to the host computer like a USB slave, but to the GPIB
devices will look like a bus controller.
JB
I think you'd be better just getting an NI USB-GPIB converter. It's not just
the hardware compatibility that's important, depending on what software
you're using, robust and well tested drivers are critical.
JB
Paul Mathews
ROB
check out ebay item 290206904947
Paul Mathews
Rich Webb
AFAIK, there is no single-chip "USB/GPIB" solution.
<http://prologix.googlepages.com/gpibusb.jpg/gpibusb-full.jpg> is a
picture of one available (and relatively inexpensive) approach.
Sparkfun carries the newer, 4.2 version; I've use the bare-board rev 3
(the one pictured) with success for some automated lab test equipment.
John Larkin
Seems to me that GPIB is, and should be, dying. Everything should just
be Ethernet. You can buy an entire Ethernet server gadget, like an
Xport, for half the price of a GPIB cable, and it will work 1000 miles
from your computer.
Ever read the actual IEEE GPIB spec?
John
Joel Koltner
The hardware design for a USB to GPIB converter is pretty straightforward --
here's one: http://lpvo.fe.uni-lj.si/gpib/. The much more time-consuming
problem -- as Paul mentions -- is that writing drivers to the level of
robustness that the folks like National Instruments or HP have done is quite
time consuming. If you want to build such a dongle for fun or largely
self-contained projects, though, this perhaps isn't a problem.
There's more to it... GPIB isn't popular enough anymore for someone to make a
single-chip interface for it.
---Joel
Joel Koltner
be Ethernet.
USB to GPIB and Ethernet to GPIB converters are the probably the last products
that will ever be commercially developed for GPIB.
No, although from having written test programs to talk to GPIB devices I
suspect it's quite massive and somewhat convoluted. :)
---Joel
Spehro Pefhany
from your computer.
John
My Commodore PET 2001 (despite the name it's ca. 1979) does GPIB..
Like this one: http://www.classiccmp.org/dunfield/pet/h/p20018.jpg
At least nobody will be able to hack into the control for a HV power
supply and electrocute anyone..
Best regards,
Spehro Pefhany
Joerg
from your computer.
Agree. However, there is lots of legacy gear that will be around for
another decade or two. Like the HP-3577. It would be nice not to have to
snap a digital camera picture every time.
I'd rather read a Steinbeck ten times in a row ;-)
F
Fred Bartoli
Yup. But get hold of a LAN-GPIB gateway (HP E2050A sell for not much)
rather than a local bus GPIB card and you'll be ready for the next
ISA/PCI/PCI express/whatever bus shift.
I did that because I wanted to switch all my PCs to linux. Plus, I can
connect from either my desktop or from a wifi laptop in the lab.
Pretty useful.
Joerg
Where do you find them? EBay was dry. All I really want to do is print
the screen contents, not control anything in the lab.
mike
Joerg wrote:
snip
Make sure you don't already have this capability.
My TEK scope has a menu buried in the menus that will print
a bitmap graphic of the screen out the serial port.
I won't call it GPIB, 'cause it's not anywhere near a GPIB
implementation. But if all you want is to send/receive
simple commands to a single GPIB instrument via a serial port,
you can do it with
a PIC processor and a couple of level translators for the serial port.
No part of it complies fully with ANY spec. Stated another way,
it VIOLATES EVERY spec. But it works for me.
Built it specifically to create an on-screen demo of a TEK TDS540
that I was trying to sell at a swapmeet. I set out to write a
Visual Basic Class module with the same API as the National Instruments
GPIB drivers, but don't remember what happened with that. Got bored
and moved on to something else.
mike
F
Fred Bartoli
Yep, ebay. I paid USD35 (+73 shipping).
There're 2 for best offer right now. I find them way too high (a new
E5810A sells for $1000) but if your not hard pressed they pop up from
time to time, so just place a search and wait.
I too don't control everything in the lab (the soldering iron isn't).
Seriously, here almost every thing is permanently connected and this has
been paid back many many times. Maybe it's worth a second thought...
Joerg
mike said:
Joerg wrote:
snip
Well, the HP3577 does offer an HPGL output and AFAIR you could actually
connect one of those old HP printers directly to it. But it does not
have a serial port :-(
you can do it with
Whatever works to get the HPGL image out would be fine.
Joerg
I'll have to look again. I've never bought anything there yet and when I
keyed in E2050 all I got was some kind of ear rings. And I don't wear
ear rings ;-)
I only need screen dumps.
N
none
For the software side, look at the program from KE5FX called hp7470.
It captures plots over the gpib and lets you manipulate, compare and
store them. I use this with my 8753, 8757, 8569 and 8562 analyzers.
It supports the NI and Prologix gpib boards. I have been meaning to
try it with one of the NI gpib-serial boxes I have sitting around.
Those boxes are cheap and plentiful. Since the Prologix uses a
serial port emulator, there may be a chance.
By the way, on your other post about ebay, search for either E2050*
or E2050A. If you leave the A off, you will not find any matches.
Doug
Joerg
Thanks. Yep, that showed it. Along with fashion socks and other stuff ;-)
Seems they now run silent auctions there as well. It appears the
Prologix solution would be a bit simpler though. I'll never understand
why HP picked that dreaded GPIB bus in the first place, with its
expensive garden hose cables and all that. The site of KE5FX is very
interesting. In case others want to look:
http://www.thegleam.com/ke5fx/gpib/readme.htm
