Mario G.
- Jan 1, 1970
- 0
I have a 5 hp 230 V AC motor on a 20 gal tank /air compressor.
When given to me by the past owner, he said it needs a new electric motor.
Since I do not have a 240 line outlet in my home, as yet anyway. I plugged
this 230 v AC motor into a 120 V ac outlet, just to see what it will do.
Well what I got was the motor did indeed spin very fast, with out it being
belted to drive the air compressor pump and all looked just fine, with out
tripping the circuit breaker, then I belted it back to the compressor pump
and started it up again, all seemd fine for about 2 / 3 min. then noticed
the compressor slowing down a little at a time with every revolution it
made, then it tripped the breaker. So even though the correct voltage was
not supplied. Can my problem be a Run capacitor or the start capacitor , how
do I test these two capacitors .Since the motor did indeed spin with out a
load I hope it is just one of the two capacitors that is prcblem only. If it
truly is the motor , does it pay to have it fixed (re-wound) or get a new
one. this one has a pivot base. Any help appreciated.
