Is there something missing in gate driver(IR2117) circuit of a buck converter? h
AbhimanyuSingh1
Jul 22, 2010
19
This gate driver is for a buck converter. The input to this IC is a nice pulse of frequency 100 KHz of variable duty ratio. I have checked the circuit many times and ensured that no shorting is there. But the output remains 0 volts. The output HO is hanging as well as the output VO is hanging. For the sake of step by step progress, I have left them hanging. Is there something I have missed or something I dont know that I should have done.
indulis
Nov 21, 2005
488
How about applying the converters input voltage to the Vcc pin of the driver.
Enforcer83
looked at the datasheet and assuming you are powering the chip (VCC) with a voltage between 10 and 20V and giving it a logic signal in the same range, there is no reason you should be having a problem.  The hookup you have given is as I have seen in the application circuit.
indulis
Nov 21, 2005
488
Your schematic shows that the Vcc pin is only connected to a diode anode, the Vcc pin also needs to be connected to a voltage (i.e. input voltage to the buck converter). If you don't connect Vcc to a voltage of course your not going to have a output!
