Is this the 'Tip & Ring' of the telephone system?
foTONICS
Sep 30, 2011
332
Hey all,
I am currently a student in telecommunications. I was painting my room and hence removed all the cover plates. One of them was a telephone jack and inside it there was a red, green, yellow, and black. I'm pretty sure the red is the -48VDC and the green is ground. What are the yellow and black wires, some sort of data for dial up or DSL? I've attached a photo for reference.
-Thanks again guys!
14,481
the red and green are the normal 2 wires used for a phone line
there's always spare wires in a cable
peter.mitchell
Feb 17, 2012
14
most telephone cables are run with at least 2 pairs, a phone signal pair and a power pair, these days since more handsets draw power from the mains, via a small adapter, the power pairs are not needed, just the phone signal pairs.
usually, the pairs for the phone signal are:
blue/white
blue-white/blue
green/yellow
and the pairs for power are
red/black
red/brown
in your case, it appears you only have one, non-standard pair (green/red), because of this i can fairly safely say it is the phone signal pair, and i can see 3 wires going into each junction, implying that one set goes to your socket on the wallplate, one pair goes to another socket, and one pair goes to the lead-in or an alarm system.
telephones haven't used a TRS [(tip, ring, shield/sleeve)phone] connector in a long time, they are similar to the connectors you see on microphones and headphones, generally only larger, more information can be found about it here: http://en.wikipedia.org/wiki/TRS_connector
TedA
Sep 26, 2011
156
FoTonics,
You failed to reveal your location, which matters in this case.
Your colors appear to be Bell System standard, where red and green are used first, and yellow and black are spares, or used for a second line.
I don't think they had Bell in Australia; Mr. Mitchell's colors are likely the non-standard ones where you are located.
Ted
14,481
actually red and green were/are the standard phone line colours in Australia as well.
peter.mitchell
Feb 17, 2012
14
Not for the past 12+ years it hasn't, and on the lead in even longer.
also, yeah, i just assumed, and as you know, assumeing makes an ass out of u and me.
14,481
I'm, like the OP, are talking about home phones which still use the centre 2 wires red and green in the modular plug.
Even my brand new printer, which has FAX facility, comes with a modular cable and it wired red/green
Of course its a whole different ball game for office systems that are digital and these days I.P. based and usually 4 wire
New Zealand went to the BT connector and cabling system in the mid 1980's, we spent years upgrading old cabling in homes to the new style
