Paul E. Schoen
- Jan 1, 1970
- 0
I have the prototype mostly done for the "smart" SCR trigger circuit
described in a previous post, and it works well enough at low power. One of
my next steps will be to install it in a test set under actual operating
conditions, which are 480 to 600 VAC fused at about 200 amperes, with
voltage to ground of 277 to 450 VAC.
Previous designs have used dual bobbin transformers rated at about 4000
VDC, and optoisolators (4N35) rated at 3500 VDC. They have been in service
for about 20 years in various forms, and there have been no reported
failures due to isolation breakdown.
In order to reduce the board size (and allow DC power), my new design uses
DC-DC converters to provide gate power. My prototype uses C&D Technologies
NMV1205SA which is rated at 3 kVDC isolation. 5 VDC at 200 mA (current
regulated) seems to be enough to fire the gates on a small 90A SCR package.
I think for the large SCRs I will need something like 12 VDC at 250 MA, but
most 3 watt packages seem to be rated at only about 1000 or 1500 VDC. I
found one from http://www.tracopower.com/ with reinforced insulation that
is rated at 4000 VDC, but its working voltage is only 300 VAC, and it costs
about $40 each (I need two).
I will probably make my own isolated voltage supply using ferrite toroid
transformers and a simple switching circuit, but that is for another post.
I would like to discuss the requirements for isolation and safety at these
high line voltages, and ways to provide protection or minimize damage from
failure.
There is an IEC standard (IEC/EN 60950, UL 60950-1) that seems to state
that normal insulation requires a rating of 1000 VDC plus twice the peak
voltage, so this would be about 1400 VDC for 120 VAC, 1800 VDC for 240 VAC,
and 2000 VDC for 300 VAC. There is also a "double insulation" standard that
is about twice these values, and I think many European parts are required
to have a 4000 volt rating. However, it did not seem to be very specific
for 480 VAC or 600 VAC.
I am mostly interested in avoiding any sort of catastrophic failure that
could cause injury to a test set operator, or a chain reaction sort of
failure that could cause carbonization, arcing, and ionization that could
lead to a severe high current fault. The SCR and the controller PC board
are located in a steel enclosure that should contain low energy faults. The
SCR gate leads are typically twisted pairs of about #22 AWG Teflon wire,
which should ultimately limit the magnitude of a fault to a couple hundred
amperes, for a few milliseconds, without extreme damage.
I thought about adding 1/2 amp fuses on these leads, but I would need four
fuses rated at 600 V (such as KTK), which cost about $12 each. This is
probably overkill. The tracks on the PC board are only about 20 mils, so I
think they would burn open and limit the damage to repairing or replacing
the board. However, I'm not sure if this is reliable at such high voltages.
If arcing and carbonization occur, a more serious fault may result.
The worst case scenario would be if a fault current entered the control
circuitry, which is in turn connected to logic circuitry. Actually, there
is a second small solid state relay in the controller which provides
another level of isolation, but at that point the fault voltage will have
entered a wiring harness which has wires rated at 300 V, and there are
connectors and terminals which might not safely insulate this higher
voltage.
I know there are a lot of SCR controllers in use, and most of them use
pulse transformers with a good safety record. There are also motor
controllers using IGBTs on 720 VDC busses derived from 480 to 600 VAC
mains, and they commonly use optoisolators and DC-DC converters without
major horror stories that I know of. So, perhaps I am being overly
cautious, but I would like to draw on your experience and knowledge to make
sure I make properly informed decisions.
Many thanks,
Paul E. Schoen
www.pstech-inc.com
failure.
voltage.
Many thanks,
Paul E. Schoen
www.pstech-inc.com
