Z
ZACK
- Jan 1, 1970
- 0
i think its just for showBruce Varley said:Just why would you run with a high filament voltage, other than to
increase burnout rate so people have to spend more on replacement?
Trevor Wilson said:**The measurements I saw were not taken with an RMS Voltmeter, but the
brightness of the filaments, compared with the same filaments operating at
the correct Voltage was clear and obvious. I'd reckon a 20-25% overload
would be in the ballpark.
You will have to find out the voltage for yourself.ZACK said:dont blame me i only found out after i got it.
you have not told us the voltage thats going
into them, or do i have to find out myself.
i know its a peace of crap.
anything from china is shit.
Trevor Wilson said:**Pop down to your local Jaycar and ask them to plug one in. You'll note
that the filaments are running MUCH hotter than normal. Just ask ZACK.
Well ZACK, tell us how bright the filaments are, compared to the filaments
in your Marshall.
clanker said:You will have to find out the voltage for yourself.
This will be most interesting.
BTW, my brother's wife is from China and she wants to meet you.
to bright.
i did ask jaycar how can you get 25watts out of a
little valve like that, ive made up outputs with this
type of tube and only got 5watts at the most
and then i found out later what was inside
was just a solid state amp.
ZACK said:why has she got better ideas for this amp.
Jasen said:to make them light up brighter?
clanker said:She thinks you might qualify as a dim sim.
ZACK said:yum dim sim.
right im going to check these voltages myself
il be back soon
Now read where someone (infinitely) more clever measured the voltagesZACK said:mmmmmmmmmmmm dim simmm
ill be back soon
6p15 pin 1-g3 12volt
pin 2-g1 -2.1volt
pin 3-c -2.1volt
pin 4-h pin 5-h 6.5volt dc
pin 6-g3 12volt
pin 7-anode 12volt
pin 8 n/c
pin 9-g2 12volt
6n1 pin 1-a1 12volt
pin 2-g1 -1.2volt
pin 3-c1 -1.3volt
pin 4h pin 5h 6.5volt dc
pin 6-a2 12volt
pin 7-g2 -6.1volt
pin 8-c2 -6.1volt
pin 9-int/sh
takein with digital meter, if you remove the tubes
one by one sound stops, so the input gos into
these tubes to the output somehowe, idont have
a schematic to se howe thay are wired il check
that out later.
swanny said:Why do that when you can stick a couple of LED's behind the valves and
make them
look like they are on![]()
clanker said:Now read where someone (infinitely) more clever measured the voltages with
a CRO and got a *real* heater voltage figure - and reason why.
clanker said:Now read where someone (infinitely) less clever "NO NEED FOR
INSALTS"measured the voltages with a CRO and got a *real* heater voltage
clanker said:Now read where someone (infinitely) "NO NEED FOR INSALTS"measured the
voltages with a CRO and got a *real* heater voltage figure - and reason
why.
why.
