Jellybean barcode driver part?
larwe
Is there such a thing as a jellybean 74- or 4000-series part that takes
a binary or BCD input and drives a bar graph LED from it?
I need to drive an 8-LED bar graph from a 4-bit data source with the
minimum of components, and right now the simplest option appears to be
a micro (well, or a PAL, but it's easier for me to develop a micro).
The drive lines are output-only and can't be switched very quickly, so
that rules out putting an I2C or SPI I/O expander on them.
Tim Mitchell
Two 74ACT138's would do it if you are happy to have "spot" mode rather
than "bar" mode.
Spehro Pefhany
You want to drive it as a moving-dot or thermometer display? If the
former, you could always use a 74HC42
That sure would be easy enough too. I guess you need 4 bits to include
all-off and all-on states.
Arie de Muynck
"larwe" ...
Yes, there is. SN7445, the old NIXIE driver (open collector, 55V 80mA).
Put the LEDs in series, upper anode to a current source. The decoder can
ground nodes sequentially.
Or, instead of a current source, use a different resistor between each
driver output and the node it drives.
Jellybean enough?
Regards,
Arie de Muynck
PS: you will need of course need a LED supply of at least 1V + 8 x Vled ...
larwe
than "bar" mode.
Sorry, it has to be a solid bar.
larwe
Has to be thermometer. There are a load of analog parts designed for VU
meters (I think) but I don't want to get too crazy with R-2R networks
and such.
Exactly. It has to show all off through all on.
larwe
Hmm, Digi-Key still stocks it... is it in production? TI's web site
doesn't give a clue.
Jellybean enough?
Definitely, thanks!
That's no problem, the board is driven by 24VDC.
CBFalconer
Arie said:
"larwe" ...
can ground nodes sequentially.
each driver output and the node it drives.
Jellybean enough?
Good thing I looked at the answers before replying. That was
precisely my solution. The major problem being that you will need
a supply of over about 15 volts for reliability. You can make the
current source with a reasonably well matched pair of pnps in a
current mirror configuration, stabilized with emitter resistors if
necessary. In which case you will need to allow about 1 volt of
overhead for the mirror.
Similar threads
Replies
6
3K
Phil Allison
Replies
4
2K
Joerg
Replies
5
4K
Franc Zabkar
F
Replies
2K
Watson A.Name - \Watt Sun, the Dark Remover\
W
