Beginner Student
- Jan 1, 1970
- 0
Hello Group,
I needed a power transistor to build a simple siren circuit and I had
some TIP32's on hand. I used one for the siren circuit and it worked
great but the data sheet I found for it shows negative voltage and
amps for all of the values listed on the data sheet. This is
confusing to me.
Data sheet is located here:
http://www.fairchildsemi.com/ds/TI/TIP32.pdf
Can someone explain why the values on the data sheet are all shown as
negative values? I am using positive voltages with reference to the
battery ground in my circuit. I know it is probably a stupid
question but I am still a true beginner when it comes to electronics.
My second question is about a nickname for these type transistors
(TIP31, TIP32..etc.) I have heard these transistors referred to as
"jellybean transistors". Where did that nickname come from. They
don't look anything like a jellybean to me. DId older versions look
like a jellybean?!
If anyone can point me to a good transistor learning resource on the
web, I would be most appreciative. I couldn't find anything about the
negative values when searching Google.
Thanks in advance for your help!
confusing to me.
like a jellybean?!
