KA7812
yourwins
Apr 12, 2004
18
How to measure KA7812 to know whether it good or bad by using Multimeter ?
Thank You!
audioguru2
Apr 6, 2004
12,022
Yourwins,
The 7812 is a 12V regulator with many transistors and resistors inside. A multimeter cannot measure if it regulates properly, but can tell only if it is shorted. I don't think that it can measure the difference of one that is blown open.
The best way to test it is when it is functioning with a proper input voltage and load.
MP1
Dec 7, 2003
3,397
...however, if your multimeter shows a short between any of the pins, you can stop there and know that the device is bad. In this case, you would have a bad result by testing the circuit with power applied.
MP
K
Kasamiko
I do a quick and dirty check by applying about 15vdc at the input and monitoring the output pin for 12vdc.. ;D
But without a load sometimes will give a false reading that drop when a load is connected..
hotwaterwizard2
Jan 8, 2004
2,022
Or you can just Pull it out and Make a simple test circuit like they have in the datasheet.
KA7812.pdf
  • KA7812.pdf
