baron
- Jan 1, 1970
- 0
Baron Inscribed thus:
Following up: The ESR measures 10-11 ohms (last digit can't make up its
mind). Peak charge current from a 5v 0.5ohm source hits 480ma (AVO 8
on 1A range) before rapidly dropping to zero. Four hours later the
terminal voltage is still 5V (Advance 10Mopv meter).
Just and update: I got the marked value wrong, its 2.2F @ 5v. There
is
no indication of the manufacturer. I've currently got a 4.5v 60ma
torch bulb connected across it to discharge it. It took a few seconds
for the bulb to stop glowing. Anyway I'm going to leave it overnight
and check its ESR tomorrow. It should be well and truly discharged by
then.
