Kenwood TS-450 Final Bias adjust
Heliman
Feb 4, 2016
65
I'm replacing the finals (2SC2879) in my Kenwood TS-450. The service manual described how to set the idle current using VR1 and VR2. My question is, where in the circuit is the ammeter connected. Ive been told by some to connect in series with the 12v line in but the manual says ANT on rear panel.
14,490
what page/section in the manual did you read that ?
Heliman
Feb 4, 2016
65
Its in the service manual. I included a snapshot of the page.
I'm sure the manual is in error. The snapshot I provided shows the final bias setting. The column shows measurement taking at rear panel on ANT terminal
14,490
that's why I asked you to clarify, and I did find the manual
it doesn't say in your above clip anything about measurement at the antenna .... really not sure where you are getting that from ??
Heliman
Feb 4, 2016
65
it says in your above clip anything about tagging measurement at the antenna .... really not sure where you are getting that from ??
14,490
ahhhh
hmmmm OK I see how that was read .... wonder of the horizontal dividing line was supposed to continue across
between 4 and 5 ?
I am not at home so don't have the manual handy, but I doubt that you will get a DC bias reading at the antenna
because of series capacitors in the output filter stages
Heliman
Feb 4, 2016
65
I know, that's is what is confusing. Im sure its a misprint or even a error in translating the manual from Japanese.
14,490
just downloading the manual again
have you read anywhere in the manual the actual text for the measurement procedure,
surely there is something more than just a test table layout ?
Heliman
Feb 4, 2016
65
There's two 12 volt lines coming from the 12 volt in jack. 1 goes to the collector of the finals and the other goes to the on/off switch. I'm just going to put the ammeter in the line going to the finals.
Heliman
Feb 4, 2016
65
Havnt seen anything in the manual other than that image I uploaded
Heliman
Feb 4, 2016
65
This service manual is the poorest service manual Ive ever seen
Heliman
Feb 4, 2016
65
I looked at the service manual to my Kenwood TS-2000 and its really clear as what to do
elebish
Aug 16, 2013
177
Just hook an ammeter in series with your 50 ohm dummy load at the antenna terminals. I believe 250 Ma is the reading at idle according to you jpg sheet.
14,490
That doesn't sound correct .... idle current is normally done in the collector supply line
Heliman
Feb 4, 2016
65
I ended up hooking the ammeter in line with the power in line. Turned both VR1 and VR2 all the way down. Checked idle current then added 250ma to each final. Turned out great. Puts out 100 watt and sounds great.
