Kitchenaid Microwave Wont Heat!
michael kali
Jun 19, 2017
MODEL KCMC1575BSS, UNIT IS 2 YEARS OLD AND ALL FUNCTIONS WORK BUT NO HEAT CHECKED MOST PARTS BUT WAS WONDERING COULD A DOOR SWITCH PREVENT HV TO THE MAGNETRON AND NOT CAUSE OTHER ISSUES?
14,487
it may be that or it may be that the magnetron has failed
regardless you should take it to a qualified service centre if you want it checked
OHH and please don't type everything is caps .... ie turn your caps lock off
on the net using caps means you are shouting
michael kali
Jun 19, 2017
thank's Dave, checked the magnetron only issue was loose cooling fins, will try pulling door switch.
