KilgoreCemetery
- Apr 12, 2017
- 259
- Joined
- Apr 12, 2017
- Messages
- 259
I have a mono block amp that won't power on. It doesn't light up at all. I pulled and checked the fuses and verified that they are good. Also, when I supply power, they do have about 12V all the way across.
When I first started looking at it, I did find 6 swollen 25V, 220uF capacitors and one 25V, 100uF. I have since replaced those with known good caps, but the amp still doesn't power on.
Recently, I found one vacant spot on the circuit board. It's a 4-pin surface mount component and I believe it is in the driver section for the power side of the amp. The down side is, I have no idea where it went or what it was supposed to be.
I checked the pads for voltage with the amp in the "on" state (12V supply and remote wire connected) and found 600mV on the two center pads, 12V on one of the outer pads, and 9V on the other (see picture).
When I disconnect the remote wire, the 600mV pads drop to zero and the 9V pad jumps to 12V.
From there, I'm stumped. I haven't been able to find a schematic and don't even have a good guess as to where to go next. Does anyone have any information on what else I could test or what may go in that spot? Any help would be appreciated.
