Q
Quack
- Jan 1, 1970
- 0
I designed a circuit running on 10v, which uses a L7805CV (morocco
MCC1A0336)voltage regulator to give me 5v for my IC's and LED's.
The problem is the 7805 gets very hot! more than enough to burn you
finger on.
Sometimes even cuts out (built in high temp. cutout).
The strange thing is, when removing the 7805 and measure with a amp
meter, i am only drawing upto 150Ma.
This particular model of 7805 is rated for upto 1.5amp (heatsink
required after 1 amp). I am using a heatsink too.
My question is, apart from the input voltage being too high, OR the
drawing current being too much, what else can make a 7805 get too hot
The circuit is running 2 pic 16f628's @ 16mhz, and a SX28 @ 50mhz, and
a few led's.
-I have ruled out too much current by removing the 7805 and using an
external 5v source and measuring current draw. (upto 150ma).
-I have checked the input voltage is between 10 and 11 volts, well
within normal limits.
-I have carefully read the specifications on this particular 7805 in
the datasheet to confirm the above limits
-I have ruled out a faulty 7805 because i have many of them, and using
a few of them randomly present the same problem.
-I have thoroughly cleaned the board of any flux residue which i
thought could create some kind of short.
-I have carefully inspected for any other shorts (in which case the
current draw in test#1 would have been more anyway)
-I am using a heatsink, even though it should not be necesary
-I use these same 7805's in another circuit, drawing a CONSTANT 450ma,
with no heatsink, and they dont even get warm.
-Removing the PIC chips from their sockets makes no difference, in
which case all that is left is a SX chip running @ 50mhz and 3 few
leds.
-This all happens even when the circuit is disconnected from any
external connections (PC serial etc).
I noticed on the SX chip development board, their regulator (LM294OCT)
gets unexpectadly warm also - is there something about SX chips i am
missing ?
I know the I/O can be set to CMOS or TTL levels, i think mine are
configured correctly - but i dont have much experience with SX chips
(this is my first SX based design).
I am out of ideas
Any suggestions of what to try/look for ?
Thanks!,
Alex.
finger on.
a few led's.
leds.
missing ?
I am out of ideas
Thanks!,
Alex.
