LA78040N Input Pin Number (Sanyo TV DS19204 Vertical Deflection)
Brad
"Kip",
I can't believe you asked that question, "R u sure its not a LA7840"!!!!
This TV is less than a year old with a new (I assume) type of vertical
deflection IC. The IC number is LA78040N. When I searched the web for pin
out information, all I found were sources where I can order this IC.
I will be very grateful if someone could tell me which pin is the input
pin? I know I can find out via circuit tracing, but I already put a lot of
time in this 19" TV, and the customer doesn't want to spend a lot of money to
get it repaired.
Thanks in advance, Brad
RonKZ650
Brad. LA78040 is covered in Sams 4466 but it's a Sansui (Orion) model.
I scanned the vert area for you. If you want it email me at
ronkz650ataol.com
Pin 1 is feedback
Pin 2 is 25v supply
Pin 6 is 25v supply after going through the diode
100uf capacitor between pin 3 and 6
Pin 4 is ground
Pin 5 is output
Pin 7 is input
F
Franc Zabkar
"Kip",
I confess that I was thinking the same as Kip.
deflection IC.
The LA7840 is still current:
http://www.semic.sanyo.co.jp/eng/product/solution/footage/colortv.htm
pin?
Here is a datasheet for the LA78040N (first hit with Google):
http://service.semic.sanyo.co.jp/semi/ds_j/N7880.pdf
get it repaired.
- Franc Zabkar
