Laser Applications???
Ammar7lb
Mar 16, 2004
13
I'v read alot of projects which depend on ultraSonic waves to measure distances and avoide barriers
So is it possible by using Laser ,I mean : Could I use Laser to measure distances and How ??
http://
surajbarkale
Aug 5, 2004
256
In the first moon mission they put up a mirror on Moon. It was used to measure the distance between Earth & Moon accuratly by bouncing a LASER back from that mirror. As the speed of light is tremendous (3*10^9m/s) you can not use LASER to measure small distances. Maybe you can measure above 500m. But I am not sure.
ante1
Jan 24, 2004
4,138
Hi Suraj,
How do you explain that the cops measure your speed with a laser? They don
Ammar7lb
Mar 16, 2004
13
Hi Ante
About How cops measure your speed ?
I think that they use UltraSonic Waves cause it is accurate and easy to use
ante1
Jan 24, 2004
4,138
Ammar,
I know that they are using laser guns to measure the speed! ;D
Kevin Weddle
Feb 23, 2004
1,620
The time there at 300 meters is 1us. The time there at 1 meter is 3.3 ns.
Kain
Jun 16, 2004
236
Yes they do use LASER for speed measuring. My friend found out in the hard way while crusing at 200+ mi/h ;D
Ammar7lb
Mar 16, 2004
13
THanks alot for your replay
Another Question: Is there any famous application which can made by using Laser??
ante1
Jan 24, 2004
4,138
Browse here for ideas:
http://homepage.ntlworld.com/electricstuff/lasfluo.html
http://www.metrologic.com/edu/global_info/funw.asp
steven2
Jan 19, 2004
1,698
intresting ive got the lazer radar detecter that detects those hand held radar guns the police use or used to use. as for lasers measureing distance yeh theyve got a spirit leveler out that uses a laser to give you the strait line and i think it measures to, ive seen it at the hardware but dident look into its function very much
F
Fatal_Byte
If you don't want to be clocked by a radar gun you have to have an anti-reflective surface all over your vehicle. Stealth bombers are coated with an anti-reflective surface also...as you might think its not cheap or practical for us.
steven2
Jan 19, 2004
1,698
:)well ive found some intresting stuff online about radar invisibility and it relates to the stuff cassette tapes are made of and onother one relates to the rusty stuff on steell when it gets rusty  are they radar obsorbant like that iron oxide on tapes or other
