Laser Lipo Clone Concept - Project Help
Status
Not open for further replies.
spdrtr
Mar 6, 2016
Hi All,
I am totally new to this forum and have to admit, I don't know how much help I will ever be in responding to other people's threads.
The main reason for my post is to test a concept for building a home-made "laser lipo" type device using source-able components.
The specs that I want to achieve or get close to are:
Technology
i-lipo includes four laser pads with 36 laser diodes
i-lipo technical specification as their body shaping.
  • Laser type diode wavelength – 650nm – 660nm
  • Energy output – 38 x 40mW (Total 1.3W)
  • Mains power output – 100Va
  • Safety – On board diagnostics
  • Classification – Electrical Class 1, Type B applied part
  • Dimensions – 32cm x 46cm x 44cm (does not include stand)
  • Weight – 9.10kg
  • Cooling requirements – Air cooled
  • Electrical requirements – 240V/5A/50Hz
  • Fuses – 5A Ceramic timed
  • Mode of operation – Continuous
  • Ingress rating – IPXO
  • Environmental 10˚C to 30˚C Non-condensing
  • Requirements – Humidities below 75%RH
Now, the areas listed under 'Safety', 'Classification', 'Dimensions', 'Weight', 'Cooling Requirements', 'Environmental', and 'Requirements' (Humidity) aren't really important. My questions are:
  1. Could a device with these capabilities be built easily?
  2. If so, could LED's with the follow specs be used?
    Features:
    http://www.aliexpress.com/item/3W-R...-1&btsid=fa5befc5-ea9b-4750-abf2-d10554698732
    Emitting Colour: Deep Red
    Color Wave Length: 650-660nm
    Reverse Voltage: 5.0 V
    DC Forward Voltage: Typical: 2.2V Max: 2.4V
    DC Forward Current: 700mA
    Luminous Intensity: 70-80lm
    Viewing Angle: 120°-140°
    LifeSpan Time : > 50,000 hours
    PCB dimension: Diameter 16mm
  3. What other components would be required?
  4. What would be an acceptable power source?
  5. How should the array be wired (series v parallel)?
Thanks in advance to anyone who is willing to help!
Alec_t
Jul 7, 2015
3,821
Welcome to EP!
:eek: I think they're vitally important. LEDs of that intensity could damage eyesight.
I'm not sure I'd trust the Technology spec: are there 36 LEDs or 38?
14,487
Thread closed
we wont get into so called health projects where hi power laser/LED systems are involved
Status
