Lately my parents have been having a hard time parking their car in the garage because of visual obstructions. I have a circuit here that will use a 5v power supply (probably plugged into the wall, batteries wouldn't last long enough)
--d1 is a laser pointer
--r1 dissipates .5V so that d1 runs on 4.5v, and at 200mA (hopefully thats the right value, correct me if I'm wrong) so it should be 2.5 ohms right?
The problem is, I'm a little bit confused about using not gates. d2 should be a photodiode, so that when d1 shines on it, r2 (which would be a buzzer or some indicator that the light beam has been broken) doesn't do anything. r3 limits the current when r2 doesn't have current through it, and r2 limits current when r3 has no current through it, am I right? r2 May be just a buzzer, or a buzzer and another resistor if the buzzer doesn't run on 5v.
Hopefully I've explained my problem, just let me know if I'm doing things right. Oh yeah, both r3 and r2 should be 25 ohms right? (5V / .2A)
Here's a link to my schematic:
