Kevin Weddle
- Feb 23, 2004
- 1,620
- Joined
- Feb 23, 2004
- Messages
- 1,620
I have this latch I want to trigger, but it is very sensitive. So I used a pull down resistor on the input. The input to the latch is the ouput of a gate. This seemed to pull down the voltage so that it would not be so sensitive to trigger with a short duration pulse. Do you think this actually works or am I just in the unknown region of the device? It seem to me that you need both voltage and duration to trigger a latch. If you want to catch a pulse, but not so often, then you can skimp on the voltage and it won't be prone to triggering as easily.
