[email protected]
- Jan 1, 1970
- 0
My backlight just went out one day on my laptop. After browsing
around, I found that it was most likely the inverter chip. I found a
replacement one and put it in. The backlight worked great for about 1
day. During that time, I had taken the opportunity to fix a noisy CPU
fan and clean out the dust from the heatsink. By the time I had
everything back together, the backlight wouldn't come on again. I
assumed that the inverter had failed, and tried another one. Still no
backlight. Either I messed something up when I had it open, or I have
developed another problem.
I tried checking the voltage coming out of the High Voltage side of the
inverter, and it stays at just around 5VAC on my meter. I thought that
this meant that the inverter wasn't working properly, but I have since
read that the inverter will probably switch off if the light isn't
attached.
The input to the inverter is a 6 pin connector. I checked the
continuity of each line on the cable, and even took off the fiber
wrapping to verify the wires were not shorted, and everything looked
fine. It appears that two lines are +5V, two are ground, and there are
two other independant lines. One is at +2V and the other is at 0V. I
know that there is probably a line to tell the inverter to turn on, and
one to determine how bright to make the backlight. I am guessing that
the 0V is the actuation line, but I am hesitant to pull it up to +5
without being sure. I traced that line to a riser board and down to
the video card, but will have to dismantle most of the laptop to
extract the video card and trace it further. I can do this if needed.
I should point out that the LCD appears to function correctly, at
certain angles I can clearly make out the data on the screen, and it
looks fine.
I am a novice at electronics repair. I am a software engineer but am
making my way into electrical engineering. This will be my first
repair of this sort.
My tools are somewhat limited, I have a nice multimeter, and an old
scope.
In you guys' expert opinions, where should I go from here? I have a
hard time believing that I was shipped two defective inverters. Could
the first have blown the CCFL? How can I be certain without
dismantling the LCD unit? How likely is it that something on the video
card is going haywire when the LCD image is fine? I didn't disturb the
video card when messing with the cpu fan.
I will be glad to give more details, pictures, run tests etc. Just let
me know what you need.
Andrew
attached.
looks fine.
scope.
Andrew
