Qualcomm_inside!
- Jan 27, 2017
- 17
- Joined
- Jan 27, 2017
- Messages
- 17
Quick question,
I have an old 720p 20" LCD TV that I was given. It is from 2005 and it is a Protron PLTV-20NS30. The problem with the set is has no backlight, however there is video on the LCD. When I press the Source key on the control panel I get a weak momentary backlight and i can see the video source; then backlight goes out.
I can hear something rattling around inside when I move the set, as well as the Ant coax plug is yanked out do is m suspecting the TV might have taken a fall.
I have not taken the back apart so I do not know if the CFL tubes are cracked or not but even in worse case I know the LCD is intact and at least one of the tubes is working. What are my chances of fixing this? Can I find these lamp tubes if I need them without buying the whole panel??
