LCD Display Driver
Status
Not open for further replies.
majkyw
Dec 5, 2013
Hello all. First post here.
I have been playing with this custom LCD display. The driver chip on it is the OKI MSM9004-02, data sheet is here http://doc.chipfind.ru/pdf/oki/msm90040102.pdf . This is pretty much my first venture with this kind of project. I tried to control it with an Arduino with some limited success, just can't seem to figure out what bits to send and when :)
Even made a rig to send bits "by hand" using some momentary switches, but the results are pretty much the same. For example, when I send 11000111 when the display is first powered up, I get 8 segments illuminated on the right side of the display. When I keep sending the same exact combination of bits, different segments illuminate in sequence from right to left. Is this what is supposed to happen? Am I doing something wrong? If anyone has any hints they will be greatly appreciated. I'm also attaching a picture of the display with all segments illuminated (I think it actually means they are all off since it's inverted).
The chip seems to be set up for 1/3 duty (pin 54 is connected to Vdd line).
Thanks for any help.
Mike
roughshawd
Jul 13, 2020
618
That doesn't look like an LCD to me, it looks like one of those florescent displays the used on high end DVD recorders....
14,317
@roughshawd : Do you ever look at the date of a thread? Or are you deliberately rummaging for necroposts to irritate us? -> locked
Status
