LCD Panel Meter Making Me Very Mad!
Um...Me123
Aug 6, 2005
174
OK So I bought this LCD panel meter to measure VDC (20Max) and I hooked a 9V battery to the power leads and it said 0.00.  Great so I hook it up again 5 minutes later it didn't work and has never worked again.  Bought another one finally several months later (has to be ordered) and I just hooked it up (said 0.00) and I hooked it up again (after going up the stairs) when I was about to put it into the panel to make sure I new the polarity and it didn't work!!!!!!! I can't get it to work at all now!!!!  What is going on!!!!  I'm really mad at this point because it's not cheap.
ante1
Jan 24, 2004
4,138
Some of these meters has a working voltage of 5.0V, have you checked its datasheet? You might have killed it!  :eek:
gogo2520
Aug 14, 2005
495
Hwllo Um...Me123
    WoW that sucks, were did you order the meters from?
    also do the meters have clips on them for the battery?
                        gogo
ante1
Jan 24, 2004
4,138
Sounds like cheap low grade quality!
gtwms
Dec 8, 2006
Most, but not all,  of the digital panel meters require an independent power source from the supply that you are measuring.
