Leakage inductance of SEPIC dual-winding inductors?
Joerg
Gents,
Dual winding inductors again. What's the leakage inductance or coupling
factor on a typical little SEPIC dual winding inductor?
Say around 10uH and one amp or so, the really flat SMT stuff. Datasheets
are silent about it and calling the mfgs is typically of little use.
When it's not in the datasheet they mostly don't know. And I don't have
one here right now to measure it.
legg
Gents,
If the characteristic isn't spec'd, then the word Sepic was introduced
by marketing. The dual winding was initially present in some parts as
a byproduct of fabrication limits - not as a requirement of the
intended design.
Bifilar is cheaper and less error-prone for more easily balanced smd
reflow-capable high-current structures. Sheilding reduces leakage.
Both work against lower-ripple sepic function.
In small regulators, app engs seem to get away with murder.
RL
Joerg
MooseFET said:
The one I measured was something like 99% for the K.
I think the winding is done with a pair of wires not one at a time.
Year back I used one from Pico that was speced as over 98%
The (bigger) ones I've used in the past were also in that ballpark. But
now I need one with an extremely flat form factor, only height matters.
Joerg
intended design.
My impression is that datasheets are much more influenced by marketing
than about 25 years ago when I started my career. If it doesn't look
good it often is left off. See my other post where a company puts a
warning in the datasheet that capacitance varies with voltage and then
.... nothing. No data, not even a typical graph, zilch.
Yeah but, when you need small form factor dual coils it is very slim
pickings. You've got to eat what's on the menu, unless you order by the
truckload.
Tell me about it. I have seen a real design where they let the core peak
to about 35% past (!) the -30% saturation point.
With app notes one has to be very careful. Often I've seen remarks like
this or that transistor needs to withstand VIN plus VOUT, completely
ignoring leakage inductance and ringout. So the reality would have been
.... tsk ... *POOF*
Sometimes I understand why switch mode converter design can be
frustrating for younger engineers.
Joerg
John said:
What is the buck side input/output voltage? What voltage/current do
you need for the negative output?
About 75V max in but could be negotiated down to maybe 60V. Minimum
input is about 35V. Output +12V at slightly less than 400mA and -12V at
100mA.
I guess I'll have to let the PWM chip scream to get as far into CCM as I
can. LTC doesn't give a max frequency but min off (low) time so I guess
that'll be my limit here. EMC will be "interesting".
Joerg
MooseFET said:
I get custom inductors in small quantities all the time. It costs me
zero extra dollars. ie: there is an extra zero on the right of the
number of dollars.
One zero would be ok but I found there's usually two zeroes tacked on ;-)
