LED in series stops circuit working
ante1
Jan 24, 2004
4,136
Hi Richard,
Welcome to our forum.
You must connect the LEDs in parallel with the fan and the solenoid. And in series with each LED there must be a resistor to limit the LED current. 8)
MP1
Dec 7, 2003
3,397
Richard, ante is correct in his comments to you. Current is the same throughout a series circuit, so your fan is not going to get enough current to run when it must first go through the LED.
You want a LED connected to a resistor to ground. If you have a 2 volt drop through the LED, then you calculate your current limiting resistor for 10V/R = LED current. (This is from 12V - 2 V)
Probably something around 2K2 will work. Depends on the LED. Check your datasheet to be sure. Also note that your circuit current consumption is the consumption of the fan plus the current for the LEDs to ground. You did not mention the current available from the transformer or the consumption of the fan, so I thought I should mention it.
MP
MP
