Led on 24v dc
Basil
Hi there all,
I want to use a LED on 24v DC what formula do i use to calculate what
resistor i need...?
the LED is a 10mm..... 30mA..... 2 volts
thankyou all
Phil Allison
"Basil"
resistor i need...?
** Ohm's law.
BTW How is Mrs Fawlty ?
............ Phil
F
Franc Zabkar
resistor i need...?
R = (Vsupply - Vled) / Current
= (24 - 2) / 30
= 0.733 Kohm
= 733 ohm
- Franc Zabkar
Lord Garth
= (24 - 2) / 30
= 0.733 Kohm
= 733 ohm
- Franc Zabkar
Don't forget the power rating!!!
P=I²R
P=(.03*.03)*733
P=.6597W
Use a 1 watt resistor or it will burn up.
Albm&ctd
P=I²R
P=(.03*.03)*733
P=.6597W
Be damned hard finding the exact resistor :) use 860 ohm and if it is
in a vehicle with 24v then 1K as the voltage gets up to about 29
volts.
Al
2004 insult page awaits your contribution
http://kwakakid.cjb.net/insult.html
H
Howard Latham
volts.
No, in the case of 24 volt vehicle , where the voltage may go up to 29
volts,
regulate to 18 volts and redo calculation on 18volts.
