LED Schematics - Help With Checking Math Please
CosplayHelp
Dec 6, 2022
4
I am working on a diagram, and I would like to get my math (and feasibility of my project) checked. I originally had it connected to an arduino nano, in order for switches changed to play different sounds, however, I was told I would burn it out. So I am looking into other ways to do so. I just would like to get my math checked on this diagram if possible, and have some help on figuring out how long the battery would last.
I am trying to make sure that my LEDs have the correct resistor values, and would like to find out how much power is coming out back to the negative. I am planning this out first, then adding in the nano later once I figure out how much this is.
I apologize that my schematic is upside down, I am still learning the symbols.
The white diode resistor somehow set to the default when I exported it, but the value was 300 ohms each.
14,317
Got a question about driving LEDs?
Use a transistor to increase the current driving capability of your Nano.
Simply add the currents from all LEDs.
The resistors for the withe LEDs are much to big:
Each resistor drops 6 V (9 V from the battery - 3 V for the LED). 6 V / 4.7 kΩ = 1,2 mA. If you want 20 mA, then R = 6 V / 20 mA = 300 Ω
Your circuit can be improved a lot in terms of component count and power dissipation:
Using the above example, 6 V × 20 mA = 120 mW is dissipated in each resistor (assuming the corrected value of 300 Ω). Connect 2 LEDs in series instead:
The resistor is then R = 3 V / 20 mA = 150 Ω, power dissipated in the resistor is 60 mW. More of the powre is available for the LEDs
For the other colors you can even put 3 or 4 LEDs inseries. Only ever as many that there is some residual voltage for the current limiting resistor. Also take into account that the 9 V battery will quickly fall below 9 V, more 8 V.
A 9 V battery is, assuming you use the typical 9 V blocks) not a good choice. For that many LEDs the battery will quickly be drained. I suggest you use a high capacity powerbank (5 V output as is common for recharging phones), calculate the matching resistors and rebuild the circuit.
CosplayHelp
Dec 6, 2022
4
Thank you for the clarifications. I will go back through and reformat it and redo the math to a 5v power bank.
