LED strobe with fading effect possible with a NE555 ?
Phil00787
Feb 27, 2023
3
This is my first post here !
Trying to make a LED blink the same way as the "beacon lights" (?) on some airplanes, like this :
This circuit, using a transistor, works fine but is very sensitive to voltage fluctuations. I can't use it as I'll draw the power from a N-gauge model train circuit (pretty dirty 8-12V).
I built some NE555 blink circuits, that work fine with the fluctuating voltage, but I can't find any which have the same look as this one, not just a square waveform, but the fading/flashing effect.
Thanks for any hints !
14,317
Could possibly be done with a 555 plus some additional circuitry for the strobing.
Possibly easier to use the transistor circuit "as is" and an additional linear voltage regulator (e.g. 78L05) to provide a clean power supply to the transistor circuit. Also very low componnet count and small size.
Phil00787
Feb 27, 2023
3
Thanks. It will be connected to a shared rail system, so I have to limit current consumption to the lowest possible. I thought about using a 7805 but was assuming (wrongly ?) that a 7805 would "waste" quite a lot of power.
bertus
3,882
Have a look at this post on AllAboutCircuits:
Bertus
Phil00787
Feb 27, 2023
3
Bertus
Thank you ! Loads of useful information there.
AnalogKid
Jun 10, 2015
3,058
I like this circuit because it gets double-duty out of the timing current; storing it up in the timing capacitor for the delay, and then dumping it through the LED. A standard 555 circuit wastes its timing current. There is a way around that, but the flash profile will not have the same look. Two things.
First, your circuit usually requires an operating voltage of at least 9 V, so a 7805 is not the right part. If you have at least 14-15 V available, a 7812 should work.
Second, the 78xx series has around 5-10 mA of current through its GND pin. That would be the additional "waste". If you can tolerate 2 additional resistors, an LM317 has a much (~100x) lower operating current. There is an "L" version in a TO-92 package for low power applications, plus various surface mount options.
ak
Delta Prime
Jul 29, 2020
2,996
.This gives the effect of a rotating beacon OR just like the lights on an aircraft tail.
