LED Table Lamp with a dimmer switch
hankentz
Mar 11, 2022
Hello
I am making a table lamp and I would like to use dimmable LEDs.
I thought I had all I need: about 2’ of dimmable LEDs, A 24V power adapter, and a dimmer switch. Yet when I put these all together I can get the LEDs to light up but they're very dim and they won’t get any brighter.
These are the parts I have so far:
ALITOVE 24V 1A 24W DC Power Supply Adapter 100~240V AC to DC 24 Volt 1 Amp Converter 24 vdc 1000mA 800mA 600mA 400mA 200mA with 5.5mm x 2.5mm 2.1mm Plug for LED Strip Light CCTV Camera DC Pump
https://smile.amazon.com/dp/B07VL8W6MQ?psc=1&ref=ppx_yo2ov_dt_b_product_details
Rhinenet Zing Ear ZE-03 Full Range Inline Table Lamp LED Dimmer Switch Incandescent Light Rotary Replacement Combo Kit 120VAC/240VAC 300W Watt MAX
https://smile.amazon.com/dp/B094J7G634?psc=1&ref=ppx_yo2ov_dt_b_product_details
3000K Warm White LED Strip Light 16.4 Feet 24V 90W CRI>80 9000LM SMD2835 600LEDs Non Waterproof with 3M Self-Adhesive for Indoor
https://smile.amazon.com/dp/B097L6QZS6?psc=1&ref=ppx_yo2ov_dt_b_product_details
Am I missing something? Keep in mind I am trying to hide all the parts within the body of the lamp so space is limited.
Thank you
Hank
Martaine2005
May 12, 2015
5,314
Hi Hank, I believe your problem is with the dimmer.
LEDs require PWM (pulse width modulation) to control brightness as opposed to incandescent lights.
Martin
