LEDs powered from AAA battery
dorabud
Jan 30, 2018
12
I have an idea on a project that involves LED Lights and I know nothing about LED s. I would like to use 3 small clear LED lights that can be lit from a single AAA Battery, is this possible?
kellys_eye
Jun 25, 2010
6,512
Possibly. LEDs require anywhere from 1.2V to 3.6V (colour-dependent) so what LEDs are you using? If you can give a part number we can check the datasheets and see what the manufacturers say.
dorabud
Jan 30, 2018
12
Don't know what lights to get, I haven't got that far.
You would most likely need some kind of boost converter to run them off a single AAA. Look up "Joule thief".
You can run them without a converter from a CR2032 coin cell, which is 3V.
dorabud
Jan 30, 2018
12
what does a joule thief do?
I am a welder by trade
It boosts the voltage from a 1.5V cell to enough to run LEDs.
Most LEDs require about 2V or more.
Audioguru
Sep 24, 2016
3,656
A Joule thief boosts the voltage of a "run down and almost dead" single battery cell to dimly light a 3V LED.
I have many solar garden lights that use an AA or AAA rechargeable cell and a voltage boosting circuit.
An AAA alkaline cell averages 1.2V during a discharge and has a capacity of 800mAh for Energizer or 850mAh for Duracell. Then it can provide 1.2V x 825mAh= 1 Watt for 1 hour.
An LED is fairly bright with a current of 20mA. Three 3V LEDs need a power of 3 x 3V x 20mA= 0.18W but the voltage boosting circuit needs about 0.1W so the total is 0.28W. An AAA alkaline cell will power them for 1W/0.28W= 3.6 hours.
dorabud
Jan 30, 2018
12
Is it possible to stack 357/303 coin cell battery to do the job. I have limited space and a joule thief looks like it may not fit in the area available
Audioguru
Sep 24, 2016
3,656
The datasheet for a tiny 357 button battery cell (or a bunch of them in series) says it is designed for a load of only 0.2mA which is about 1/300th of what you need. It has a capacity of 138mAh at its tiny current but an AAA cell has a capacity of 825mAh at the much higher 180mA of current you will need.
What do you expect to do with these three ligths. Are they expected to give out significant light (like a flashlight) or just be visible (like an On indicator?)
If the latter, under what lightng conditions? For normal indoor lihting, a modern high-efficiency LED can be run at 1 mA.
dorabud
Jan 30, 2018
12
The area these lights are to used is normally unlighted but sometimes a light is required to make sure a part is in location, we use a small flash light now. I have 3 holes (about 1/4in Dia and on a 3" bolt center circle) through the punch that the lights can be placed. Normally lights are not required the light will give the operator a little better hands free check. The Area that I have to place the Battery and things is W3/4in x H5/8in x L2 3/8in the switch will mounted in an area about 6" away. this would be a normally off switch. The purpose for the lights is to free up the operator hands for safer operation. The lights will only be on for about 2 to 3 minutes at a time.
OK, so you do probably want something like 20mA for each LED.
And you presumably want white, which require over 3V.
I would go with a small LiPo battery like these:
Small LiPo battery
I am using these same batteries for some LED strips and I am very happy with them.
And they are rechargeable.
These would run 3 LEDs at 20mA each for about 6 hours before needing recharging.
Audioguru
Sep 24, 2016
3,656
You also need a charger for the battery. Maybe buy a quadcopter and use its charger.
A name brand 9V alkaline battery will power two LEDs in series plus a third LED by itself for about 15 hours. Current limiting resistors are needed.
dorabud
Jan 30, 2018
12
Check my wiring, Battery - to light1, light 1 to light 2, light 2 to light 3, light 3 to switch, switch to Battery +, Completed?
dorabud
Jan 30, 2018
12
going to order the part that you suggested, is there anything else that I might need and thanks for all the help,
You need a resistor (or multiple resistors, depending on how you wire the LEDs) to limit the current through them.
LEDs are not like light bulbs.
In our resources section we have a resource about LEDs. Sections 1 and 2 would be the most relevant to what you're doing I think.
dorabud
Jan 30, 2018
12
Please be patience this is way above me. Now that I have the battery and the LEDs, I also need resistors?
How do I determine the correct resistor? Thanks you for the read but I'm still a slow on this hole thing, and may have to read this a couple of times.
